Old 11-09-2009, 04:12 PM   #1
mr_mikes7
Leaden dullness cannot soar
mr_mikes7's Avatar
My Ride: 2004 330i ZHP
DIY: RTAB Replacement (warning: delrin content - pansies beware)
Removal of stock bushings:
1. Loosen the lug nuts on the rear wheels while the car is on the ground, then raise the rear of the vehicle and place on jack stands.
2. Remove rear wheels and be prepared to get dirty.
3. Disconnect rear shocks.
4. To allow the trailing arm to drop lower (making it easier to remove the RTAB), disconnect rear sway bar. (This might not be necessary with stock sways, but mine were Hotchkis and were getting in the way.)
5. Locate the front of the trailing arm.
6. Locate 3-18mm bolts and remove. (It will be important to install the bolts and the bushing console in the same position. The bolts leave a mark in the console, so you can use those, or you can use a sharpie to draw circles around the bolts before you remove them.) Be sure to also unclip the wires.
7. Here is the bushing and console after it is lowered.
8. Use an 18mm allen wrench and a breaker bar with an 18mm socket to remove the through bolt. Note orientation of console after removing.
9. Close-up after removing console.
10. Now the fun begins. Since I purchased my RTAB's from TC Kline, they let me borrow their removal tool (with a deposit) for free. The tool made the removal very easy. I highly suggest getting your hands on some type of professional tool before attempting this DIY.
11. Proper pieces of the tool assembled for E46 RTAB removal (this tool kit can also be used to remove other bushing on an E46/E36 rear axle).
12. Tool installed and ready to be used.
13. And after a few turns of the allen wrench...
Installation of new bushings:
1. TC Kline Delrin RTAB's
2. Use the supplied green Loctite on the inside of the carrier or the outside of the bushings.
3. Slide each end into carrier as far as they will go.
4. Using the tool, assemble the correct pieces for an RTAB installation, and press both sides into the carrier making sure they go in straight.
5. Bushing correctly pressed in.
6. Grease the center bearing (using a non-petroluem based lube). I used Lubriplate.
7. Press bearing through the bushing with your hands. It should glide in without much difficulty. Towards the end I used a rubber mallet to get it flush with the bushings.
8. Grease the inside of the washers.
9. Place washers on the outside of the bushing.
10. Reinstall console and tighten through bolt to 81 ft/lbs.
11. Reposition console (using a jack to raise the arm will help) and reinstall 3-18mm bolts. Tighten to 57 ft/lbs. Reconnect wire and also the rear shock and sway bar if you disconnected it earlier (after completing both sides).
12. Repeat for other side.
mr_mikes7 is offline   Reply With Quote
Old 11-09-2009, 04:15 PM   #2
ChrisTKHarris
My Ride: 325Ci
First!
-Chris
ChrisTKHarris is offline   Reply With Quote
Old 11-09-2009, 04:19 PM   #3
neil1138
Cinnanomnomnom
neil1138's Avatar
Yay, now fix your photos my friend
neil1138 is offline   Reply With Quote
Old 11-09-2009, 04:42 PM   #4
ChrisTKHarris
My Ride: 325Ci
I see pics now
-Chris
Old 11-09-2009, 04:51 PM   #5
BMW_Matt
BMW_Matt's Avatar
My Ride: turns L to turn R
Nice DIY. Notice any changes in the car's handling aspect?
BMW_Matt is offline   Reply With Quote
Old 11-09-2009, 04:54 PM   #6
Eazy-E46
My Ride: 330ci
Nice scissoring session
- Kris -
Eazy-E46 is online now   Reply With Quote
Old 11-09-2009, 05:23 PM   #7
mr_mikes7
mr_mikes7's Avatar
Huge change. I do believe my stock bushings were shot, but after I put these in, everything is solid. No more dips when shifting, and it now feels like the shocks are doing the work they are supposed to.
The ride quality is more harsh over bumps, etc., but it is not unbearable.
No squeaking either. I think these are a much better design over UUC and Rogue RTAB's. (And Rob, before you post, I have seen your RTAB's.)
Old 11-09-2009, 05:29 PM   #8
BMW_Matt
BMW_Matt's Avatar
Price paid? And dam, I wish I was in Cali. I don't know of anyone who would have a removal tool that I could borrow tho
Old 11-09-2009, 05:32 PM   #9
mr_mikes7
mr_mikes7's Avatar
$146.30 for the bushings
$460.00 for the tool
TC Kline also has a location in Hilliard, Ohio. You basically buy the tool from them, and then return it when you are done and they will issue a full refund for the tool (as long as you don't break it).
Old 11-09-2009, 05:47 PM   #10
BMW_Matt
BMW_Matt's Avatar
Lol dammit. I'm not driving to Ohio to get a tool I'll spend $200 in gas money to get there lol. How much do you think a indy shop would charge for install? 1 hrs labor? And is it possible to do it without the tool?
Old 11-09-2009, 05:49 PM   #11
mr_mikes7
mr_mikes7's Avatar
I called my indy shop before ordering the tool, and they wanted $350 to do the install. You don't have to drive anywhere to get the tool though... they sent it to me from Ohio via UPS.
Old 11-09-2009, 05:50 PM   #12
BMW_Matt
BMW_Matt's Avatar
ohhhhh! Well sheit that works awesome. How much was shipping?
Old 11-09-2009, 05:57 PM   #13
mr_mikes7
mr_mikes7's Avatar
$19.28 - and that was from Ohio to CA.
Old 11-09-2009, 06:00 PM   #14
BMW_Matt
BMW_Matt's Avatar
So it cost you about $160-ish to install stiffer RTAB's to replace old one's...Nice
They much stiffer than OEM?
Old 11-09-2009, 06:05 PM   #15
mr_mikes7
mr_mikes7's Avatar
Yes, about $160. These are much stiffer than OEM. OEM is rubber, and these are a solid plastic.
Old 11-09-2009, 06:11 PM   #16
BMW_Matt
BMW_Matt's Avatar
Hmm. I'll take a look at all my bushing's the next time I change my oil and if need-be put it on the "spring cleaning" list. Along with some re-01r's from a certain someone
Old 11-09-2009, 06:16 PM   #17
mr_mikes7
mr_mikes7's Avatar
It may be hard to tell by simply looking at the bushing. Mine looked perfectly normal, but when driving I could feel much more bump steer.
Old 11-09-2009, 08:10 PM   #18
n2Bimmer
My Ride: Loves Corners
Very nice. Do these make noise?. I think ive heard of Derlin breaking, im not sure, Over at the M3forum.
Old 11-09-2009, 08:13 PM   #19
mr_mikes7
mr_mikes7's Avatar
No noise so far. One really nice design is that the inner part (where the bearing goes through) is "rifled". There is a spiral groove machined into the delrin to keep the lube inside. Also, the large metal washers help protect the delrin from the console, and further keep the lube locked in the center of the bushing. I don't doubt that delrin could break - it is plastic after all, but I don't see how these bushings would break inside of the carrier.
Old 11-10-2009, 03:14 AM   #20
SHOF
Car Ramrod
SHOF's Avatar
My Ride: M3
SHOF is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
