Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
The Tire Rack's Tire & Wheel Forum
Use this forum to discuss anything in relation to wheels to tires to offsets. Sponsored by The Tire Rack |
#1 |
*rim removal problem*
so i ran over a screw and and i need to take my tire off. i put it up on my floor jack and took all the lug nuts off. it has a mcgard lock nut which i also took off. with all the lug nuts off the tire still wont budge to come off..ive got breyton spirit rims...is there any other locking mechanism i should be aware of.i cant drive it so taking it to a shop wont do me any good..anyone got any suggestions???
#2 |
mine gets stuck, so i just give it a few hard kicks, or figure out a way to pry it off. i dont think theres a lock or anything holding it. probably just stuck real good.
#3 |
might just be stuck to the hub...if you have a rubber mallet or sumthin just give it a few good hit on each side closest to the outer edge until it comes loose
![]() 1997 E36 M3 MODS: AA Diff. Support, UUC SSK, Euro headlights, UUC headers, UUC exhaust, ACS TYPE III replica Rims. Porsche "meteor Gray" paintjob, smoked lights, UUC RTAB, UUC RSM's Soon: Suede headliner, Alcantara euro steering wheel, ACS interior, Supercharger.
#4 |
kick it, if that doesnt work take a mallet to the inside(just incase you miss and dont smack the face of the rim)
![]() Sig by NorthJersey3er 2001 LSB/Cinn M3 - euro.techniks east - - Mobile Addictions - - Euro-Spec.net - - Beemer Evolution - |
#5 |
^+1, just keep kicking the damn thing. one time i had to use steel toe boots, and i just roundhouse kicked that sh!t, and it popped right off. I did it to my m68s which i didnt care about, so maybe try something more gentle with your rims
![]() ![]() Depo Corners & Sidemarkers, CCFL AE's, Yellow fogs, M3 Mirrors, M3 trunk lip spoiler, M3 Seats, Smoked Eagle Eyes, Shadow trim & kidney's, E46 fanatics Decals =) **Muz Khan** |
#6 |
yeah its stuck on pretty good,ill see what i can do
#7 |
Yeah, it's called rust.
Imola Red 2004 330i ZHP | ESS TS2+ SC | KMS 3.23 LSD | AST 4100 coilovers | APEX ARC-8 (coming soon) | H&R anti-roll bars | Vorshlag camber plates | Vorshlag RTAB limiters | TMS subframe & swaybar reinforcements | UUC SSK & DSSR | UUC TM & TME | BimmerWorld engine mounts | Dinan strut & shock tower bars | EMP Stewart water pump | XM Radio |
#8 |
Kick it at twelve O'clock really hard works all the time for me....
#9 |
haha yup i can see it fall as im kicking the tire...damnit this thing is a b!#%$ to take off
#10 |
put the lug bolts back in loosely and SLOWLY and GENTLY lower the car back down to put some weight on the wheel and it should break it free from the hub
#11 |
My Ride: 1:25 Scale Enzo
Slight nudge works well for me and is safer then lowering the car back down on loose lug bolts.
-Charles@VMRWheels
Charles @ VMR Wheels Email - charles@velocitymotoring.com Tel - 714.442.7916 ext 107 [24 Hour Live Inventory] [**NEW VMR V701 Straight Spoke**][**NEW VMR V718 Signature Mesh**] ![]() [V713 19"] [VMR Wheels Gallery] [Connect with us on Facebook!] |
#12 |
after kicking the damn wheel for a good 20 min the thing still doesnt want to come off. kicked it everyway imagineable still no luck.
#13 |
My Ride: 2001 325i TiAg
It's stuck to the hub. Kick it. Face away from the wheel (your back to the car), brace yourself by putting your hands behind you and on the car, then give it a swift backwards kick.
I hate wagons... |
#14 |
time to try the technique jmay87s mentioned.
#15 |
would it not be wise to put the lug nuts back on lower the car and roll it forward and back..its as if the rim is welded to the damn hub
#16 |
get a peice of 2X4 and a 10 pound hammer. put the 2x4 on the face of the rim near the edge and hit it with the hammer. work your way across the wheel in a criss cross pattern like you if you were torqueing the lug bolts. this normaly requires two people, one to hold and one to hit. theres some company that sell a very thin shim to put in between the rim and hub. i normaly wire bush the rust off and keep it in out of the rain to minimize rusting.
#17 |
finally got the tire off now that i plugged the hole should i retorque the lug nuts.. what happens if i just tighten them and not torque them.?
#18 | |
Ive had to put a floor jack in between the frame of the car and the rim before, no fun.
Also maybe put a little WD40 on the hub and give it a good scrubbing with a wire brush to get some of the corrosion off, do the same for the bore of the actual wheel.
#19 |
My Ride: 01 325xi
When you do eventually get it off, wire brush the hub contact points and put a very thin layer of grease on the face of the hub where the wheel contacts to prevent this from happening again.
#20 | |
If you were to bolt the wheels on without torquing them, it is unknown how many ft/lbs it is being tightened down to. The recommended BMW spec is 88 ft/lbs. This is definitely a huge safety hazard so I would recommend trying to source an accurate torque wrench when installing. -Charles@VMRWheels
