Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
LED tails
I installed smoked LED tails and the indicator lights on my dash would show up upon starting of the car then would go away...whats goin on?? how do i get it to not come on?
#2 |
FCP Groton Representative
Did you run a resistor in line with the turn signals? If not, that could be the issue.
FCP Groton Andrew Owendoff Communications Facilitator Old Saybrook, CT +1.877.634.0063 FCP Groton Official Website <- Click! AutoBlock - World Class Media Follow us on Facebook & Twitter! |
#3 | |
im quite noob..sry if i didnt answer your question =\
#4 |
No, that is ok. Normally when you put in LED turn signals, you need to put in a resistor like this:
![]() Across the positive and ground wires for each turn signal. Are the turn signals working like they should when you use them normally?
#5 |
yes they work...all the lights light up...soo im suppose to line them up and not have the wires clustered together?
#6 |
What lights did you get?
Jake - 2002 330i
#7 |
1.888.JLEVISW
Ok LED tails and LED turn signals are two different things. Typically LED tails will have preinstalled resistor boxes like the eagle eyes, you should not have to install additional resistors with these boxes. However, I noticed you have a Canadian model which could complicate things, there are US spec and Euro Spec LED tails from Eagle Eyes which may be causing the issue.
#8 |
ok..so if i leave it as it is...will there be anything bad to it?
#9 |
As long as they aren't "fast-clicking", and you can live with seeing the errors, it doesn't cause any real damage from our experience... other than being annoying. Where did you get your tails?
Contact us via live chat on our website if you need troubleshooting help. Double check the grounding on them, while it may not cause them to flicker, a loose ground can sometimes cause errors at start up that mysteriously disappear as you drive. You can contact one of our tech's via live online webchat if you have questions. |
#10 | |
Now is there any way that I can make my own resistor? http://forum.e46fanatics.com/showthread.php?t=719863 |
#11 |
Hmm,
I wouldn't know how you would "build" your own resistor, but you could probably find a suitable one at your local stereo shop. We use 50W resistors, which are somewhat widely available. You may not find them at your local .... walmart?...but most shops that deal with 12v electronics will probably sell you one for a couple bucks.
