Old 11-12-2009, 04:47 PM   #1
330inthe330
My Ride: TiAg 330cic
Clicking sound coming from rear passenger side. Help?
While rolling at low speeds (10-30mph) I have occasionally (1/3 of the time) been hearing a clicking sound that immediately ceases when i touch the brake pedal. Upon release of the brake pedal, it comes back. I took both rear wheels off and looked around my brakes and suspension for something loose, and let my car idle in drive while the wheels were off and couldn't get the noise to occur. My pads and rotors are oem and in perfect condition.
The sound is a "chick-chick-chick-chick" sound like something is scraping.
My suspension is stock sport package, on oem bmw 18's
Any suggestions/input as to what this could be?
I'm relatively new to bmw's and I did search this topic, only to find one case of the sound, which the OP said it was a hub? I don't understand this.
All responses are appreciated.
330inthe330 is offline   Reply With Quote
Old 11-12-2009, 05:55 PM   #2
bishop1977
My Ride: 04 330i ZHP S/C
could be a worn sway bar endlink bushing or a loose strut
bishop1977 is online now   Reply With Quote
Old 11-12-2009, 07:12 PM   #3
330inthe330
Would that be affected by the slightest touch on the brake pedal? I'm talking slight as in not enough to make your cruise stop. The lightest depression of the brake pedal makes the sound completely go away, and there is no sound at all from the back of the car when i do that, but when i release, the clicking comes back.
and another note: the noise does not variate when turning either way.
Old 11-13-2009, 01:57 AM   #4
330inthe330
any past experience or ideas will be considered, i just want to figure this out and get it fixed. it's really annoying to drive it like this.
Old 11-13-2009, 03:47 PM   #5
330inthe330
This is how I feel every time I hear the noise -->
Old 11-16-2009, 12:04 PM   #6
serial
My Ride: E46 320d
same problem here
do you feel any vibrations when braking?
I checked to see what it was and it looks like a slightly warped rotor that brushes against the pads at one point and thus making a clicking sound.
You would think it wouldnt be a clicking sound but anything over 1mph and it starts to sound like clicking.
serial is offline   Reply With Quote
Old 11-18-2009, 09:07 PM   #7
Monza_dh
My Ride: 2002 330Ci
Do you have spacers? I had this same exact issue that I thought was first a CV joint but they were ok. It did go a way once I removed the wheels again and cleaned around the hub and wheel and spacers. I think the spacer was causing the issue because since then it hasnt come back sinc they went on and were tourqued correctly.
'02 330ci Sedan
Manual, Sport, OEM 18"s, Dinan CAI, , Exhaust, TB, Stage 3 SW
'88 911 Carrera 3.2
Monza_dh is offline   Reply With Quote
Old 11-20-2009, 07:10 AM   #8
figjam911
My Ride: 323i, 1999,
Hi,
It is the ebrake and it needs adjustment. Mine does the same and I just haven't gotten around to fixing it yet. Search 'ebrake noise' or the like here and you'll find all about it !
Cheers
Colin
1999-323i Steel Grey, black leather, CD stacker, tinted windows, reversing radar, Michelin XSE on M3 17" alloys.
Colin Boucher
figjam911 is offline   Reply With Quote
Old 11-21-2009, 10:05 AM   #9
serial
My Ride: E46 320d
prob seems to have been solved by replacing the front wheel bearings on both sides
rear clicking sound
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
