Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 11-17-2009, 08:00 PM   #1
HPF Chris
My Ride: 2002 M3, 2006 530i
Thumbs Up HPF Stage 2.5 M3 Has a New Tune with More Power!!!!
Why The New Tune
We just finished testing the new Billet wheel turbo from Precision which gave JP a lot of time to spend tweaking the tune for the stage 2.5. The reason for investing 2-3 weeks and several turbos in 3 different stage 2.5 M3's was to fix a problem that Scott Wheeler was having. In Scott's M3 (HPF Stage 2.5) on long pulls to 190mph the HPF safety knock siren would go off often between 170 to 180mph. He would then lift and was unable to do his 200mph pull. Most stage 2.5 customers don't hit these higher speeds because most E46 M3's are still limited to 165mph by the factory speed governor. Scott had his speed limiter removed by Active Autowerke.
The First Solution Tried
Our first solution for Scott was to reduce the timing, so we dropped the timing back a couple times in his M3. We pulled a total of 8 degrees of timing from our standard map and the knock siren still went off above 170mph. This is also why his car went from a 5.85 60-130mph to a 6.3 60-130mph. Since we couldn't datalog his car remotely we wondered if the air was possibly getting too hot on these long pulls and triggering a pre-ignition event causing our safety knock siren to go off. Scott wanted to try our stage 4 intercooler which we didn't have a tune for, and we wanted to possibly try a bigger turbo that would make colder air.
The Second Solution Tried
Our 2nd solution was to try a different turbo which would require us to have cars in house to test with and a different turbo to try. We chose to try the new Precision 67 Billet wheel with an H cover as we liked the improvement we achieved with the new 71 billet H cover in our stage 3 turbo kits. What we found after testing these side by side in 2 different M3's was that we gained some on the top end but the quick spool was compromised. After much discussion we determined that for the horsepower gains we saw on the big end it wasn't worth the loss in spool on the small end. So we decided to not use the Billet wheel 67 turbo w/H cover from Precision on our stage 2.5 kit.
The Final Solution
What we determined after 2-3 weeks of testing was that the low compression motors for stages 2.5, 3 and 4 make a bit more natural noise than the high compression engines from the factory. The natural noise of an engine is defined in the EMS in a table which relates RPM to knock volts. Anything above the values you specify trigger the safety knock siren to go off, they also trigger a timing retard to protect the engine along with a quick burst of extra fuel to instantly drop EGTs. JP originally had this knock noise table the same for all our our M3 turbo kits (stages 1-4). During the past couple weeks he re-defined it for our built motors turbo kits (stages 2.5, 3 and 4) to reflect the built engine which allowed him to adjust the tunes and pick up power. Our new HPF Stage 2.5 tune now makes even more power with less boost as you can see from the graphs below.
Adjusting this knock table to the natural frequencies of the engine makes the safety knock siren now go off when pre-ignition truly occurs.
Precision 67 Billet Wheel H-Cover vs 67 Cast Wheel S-Cover (Cast Wheel Chosen)
Stage 2.5 Tune Change (Original Turbo) - Pump Gas
Stage 2.5 Tune Change (Original Turbo) - Race Gas
STAGE 1 M3 TURBO KIT SALE - $13,500!!!!
HorsepowerFreaks
12905 NE Airport Way
Portland, OR 97230
(503) 256-5600
Turbo Kit Information, Customers and Videos - E46 M3 Turbo Kits
BMW Parts For Sale - BMW Performance Parts
Product questions or to purchase - david@horsepowerfreaks.com
HPF Chris is offline   Reply With Quote
Old 11-17-2009, 08:18 PM   #2
MGB009
My Ride: 2006 330ci ZHP 6sp
Nice work guys. Its always great to see a tuner go back and refine existing products to add value to the customer, especially in this case where there is not and immediate ROI for the tuner.
MGB009 is offline   Reply With Quote
Old 11-17-2009, 08:27 PM   #3
Forcefed M3
HPF no resistor needed!
Forcefed M3's Avatar
My Ride: HPF Stage 2.5 M3
I just cried..so beautiful..car going down next week for my retune..awesome work guys..
19 inch Iforged Daytona's, HPF Exhaust.
HPF Stage 2.5 #007
Want to save $250.00 on your HPF kit..pm me and ask me how!!! I have the secret squirrel hook up! Subscribe to my youtube account for my new video's http://www.youtube.com/user/HorsepowerfreaksM3
Forcefed M3 is offline   Reply With Quote
Old 11-17-2009, 08:38 PM   #4
Ravij
My Ride: 3.5 IR vert M3
Great work Chris! And Major props to Jp! Any stage 2 love?
Ravij is offline   Reply With Quote
Old 11-17-2009, 08:46 PM   #5
xcoolnessx
My Ride: Rover
Wowza, does this mean All I have to do is send my ECU in for the retune? Do I have to pay anything?
HPF M3 AKA on supraforum SupraKiller
AKA z06forum VetteKiller
AKA svtforum SVTkiller
Photobucket
xcoolnessx is online now   Reply With Quote
Old 11-17-2009, 09:01 PM   #6
HPF Chris
Just send the ECU and we'll upgrade your tune for free. However.... you could return the favor by making some more videos.
Thanks Ravi... I definitely think you've maxxed out the stage 2. Just take the step to 2.5 or 3...
Chris.
HorsepowerFreaks
Portland, OR 97230
(503) 256-5600
Old 11-17-2009, 09:05 PM   #7
xcoolnessx
My Ride: Rover
Now that is what I call CUSTOMER SERVICE!!! I'll send mine out Monday as I want to drive the car over the weekend Yes, I owe you vids and I will have some, I promise.
Photobucket
Old 11-17-2009, 09:07 PM   #8
SPDu4ea
My Ride: .
time for a new plate (700 RWHP)
SPDu4ea is offline   Reply With Quote
Old 11-17-2009, 09:13 PM   #9
MSpired
My Ride: VF SC '02 BMW M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
Hell ya, I always loved your runs and it's been a while!
MSpired is online now   Reply With Quote
Old 11-17-2009, 09:17 PM   #10
ST06M3
My Ride: 2006 E46 M3 ZCP
Great job to Chris and crew.
Cant wait to get my car back and hopefully break some records.
2006 E46 M3 ZCP | IB | 6spd | AP Exhaust | UUC SSK | Custom Alum Pedal set | Alum Rear Control arms | HPF Feramic Clutch | Vorsteiner CSL Front Spoiler | Vorsteiner Rear Diffuser | Tint
Previous: HPF Stage 2 | 60-130mph @ 6.86sec
Current: HPF Stage 2.5
ST06M3 is offline   Reply With Quote
Old 11-17-2009, 09:24 PM   #11
Ravij
Chris.
No Problem! haha, Yea you are right, but i got this stupid boost bug! I might take your stage 4 off your hands!!!
Old 11-17-2009, 09:25 PM   #12
mpower95
My Ride: E46 M
Amazing, you guys always seem to raise the bar!
mpower95 is offline   Reply With Quote
Old 11-17-2009, 09:29 PM   #13
SPDu4ea
My Ride: .
Bunch of questions for Chris:
1) 750cc injectors should be just around 80% duty cycle for 600rwhp -- is the meth injection really supplying 100rwhp worth of fuel or are you running higher fuel pressure (>70psi at 25psi boost)
2) Did you happen to try the billet wheel with the S-cover?
3) Do you know what kind of gains a stage 2.5 car could expect from:
a) CF intake
b) stage 3+ exhaust (the above dynos are still on the stock rear section, correct?)
c) stage 4 intercooler
4) With the revised knock threshold tables, should we expect new numbers (and tunes) for stage 3 and stage 4? (and have you seen/considered the new Garret GTX-R turbos for stage 4+?)
And once again, major props for the ongoing R&D
Old 11-17-2009, 09:43 PM   #14
docwyte
My Ride: '02 M3
Why are the lower compression motors more knock noisy?
'89 Porsche 944 Turbo INCOMING
'92 Audi S4 INCOMING
docwyte is offline   Reply With Quote
Old 11-17-2009, 09:50 PM   #15
BadBoostedBmwM3
My Ride: 323i & e36 Turbo M3
Awesome.... Chris!! Im impressed again. Close enough to 700rwhp for me. There goes the 60-130 time again!
This is my signature....
BadBoostedBmwM3 is offline   Reply With Quote
Old 11-17-2009, 09:51 PM   #16
BadBoostedBmwM3
a) CF intake
Well, i know the OEM FPR is 5.0bar so that ~71psi. And, I believe the regulator is 1:1 ratio... so they would be about ~93psi in boost, if the regulator is 1:1 ratio.
Old 11-17-2009, 09:56 PM   #17
SPDu4ea
My Ride: .
It's fairly common (and probably completely unrelated to compression ratio). Engines built for big power need to reliably handle a lot more heat & pressure than stock, so they usually have tolerances set slightly larger (looser) than factory builds. This results in more mechanical/background noise...
Old 11-17-2009, 09:57 PM   #18
SPDu4ea
My Ride: .
holy crap, I'm used to seeing 40-50psi base pressures in Supras. Makes sense now...
Old 11-17-2009, 11:02 PM   #19
RACEMX-M3
My Ride: M3
Chris, awesome results. This should be good for a slightly faster 60-130 for the 2.5.
HPF Stage 2.5 #0001 - World's Fastest BMW from 60-130 @ 5.75 seconds
RACEMX-M3 is offline   Reply With Quote
Old 11-17-2009, 11:52 PM   #20
leletyM3
My Ride: 05 M3
Can't wait to see some new vidz from you!
05 BMW ///M3 SMG - Jet Black/Gray
HPF Stg2 Turbo 640rwhp, Eisenmann Race 83mmx4, Volk TE37 TA, Toyo T1R, Brembo BBK 380mm 6pots & 345, 6k HID, 6K HID Fogs, Depo Smoked Corners, Strassentech Front Lip, V-CSL Bootlid, V-CSL Diffuser
leletyM3 is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
