Old 11-19-2009, 12:04 PM   #1
tbush
My Ride: 2005 330xi
xi front swaybar
I'd like to find a stiffer front swaybar for e46 x drive. Many of the aftermarket guys, like UUC, Turner, Eibach, H&R, don't offer one. Any suggestions?
tbush is offline   Reply With Quote
Old 11-19-2009, 12:10 PM   #2
Bimmer Dude Xi
My Ride: 03 325 XI
Send a message via AIM to Bimmer Dude Xi
no one really offers one except one company.
search for xi sway bar and you'll find the thread
Bimmer Dude Xi is offline   Reply With Quote
Old 11-19-2009, 01:35 PM   #3
Mark M
My Ride: e30M3, 325xi, 135
No offense, are you sure you really need a stiffer front bar? Maybe you really need stiffer springs?
On my xi I have the H&R coilover kit and it is literally flat as a rail. I scare myself how fast I can enter corners with this car and it just holds tight with no understeer at all. I am running 225/45/17Goodyear F1 DS3 tires.
Also, I am quite accustomed to fast driving and done more driver's schools than I can count in my E30 M3 and E36 M3. So just putting that out there so you can understand my above comments were not just heresay from a teenager, but actually fact based.
What setup are you currently running?
Mark M is offline   Reply With Quote
Old 11-19-2009, 02:47 PM   #4
tbush
My Ride: 2005 330xi
Thanks, Bimmer Dude xi. I should have searched before posting. It seems like Racing Dynamics is the only possibility, if they have any in stock.
To Mark M., I am stock, except for UUC rear sway.
Old 11-19-2009, 03:20 PM   #5
Bimmer Dude Xi
My Ride: 03 325 XI
i spoke to them in august and the rep said they should some set by october but i never really gave another call back.
give them a call and find out. if they do let us know
Old 11-19-2009, 09:16 PM   #6
Mark M
TBush....why wouldn't you change springs before going with a bigger bar? Anything you read on proper suspension setup tells you that the spring rates should be the primary way of balancing the car where as the sway bars are only a secondary tool.
The problem with a strong bar combined with weak springs is that you are forcing too much load through the bar which in turn is going to tear at the bar's mounting points and eventually wear out the bar's bushings, endlinks, or even rip free from the car's body. Further, a stiff bar only works to reduce the independence of your German suspension system.
Just urging you to rethink your approach and perhaps first start with upgraded springs / shocks. What is it you are actually trying to achieve?
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
