Old 11-20-2009, 12:42 PM   #1
bmw02ci
My Ride: CI-coupe
Question Clunking Sound From Front
Hello everyone Lately I notice some clunking sound comes from front suspension when driving on rough road. Could it be shock absorber issue?
I have:
2002 325 CI Coupe with 110K on the clock.
Thanks in advance for your advice
bmw02ci is offline   Reply With Quote
Old 11-20-2009, 12:49 PM   #2
Countdownbmw
Lets Go Lakers!
Countdownbmw's Avatar
My Ride: 330i ZHP 6 MT, 318is
Countdownbmw is offline   Reply With Quote
Old 11-20-2009, 12:51 PM   #3
Rocket22
My Ride: 2003 325Ci
when in doubt, change the control arm bushings
That seems to be the general rule. After almost a year of postponement, I am finally completing this repair over the weekend.
Rocket22 is offline   Reply With Quote
Old 11-20-2009, 12:54 PM   #4
bmw02ci
My Ride: CI-coupe
Thanks Countdownbmw, that could be it. Do you know how much the parts cost?
Old 11-20-2009, 12:54 PM   #5
n2Bimmer
My Ride: Loves Corners
Easiest way to test is jack the side of the car up. Have someone move the wheel left to right, Look at the bushing, if there is alot of movement then the bushings are bad. Good time to do the control arms too at that mileage.
Old 11-20-2009, 12:57 PM   #6
bmw02ci
My Ride: CI-coupe
Rocket22, looks like you have 325 CI as well but newer. Did you experience the same problem? What are the parts cost alone?
Thanks,
Eddy
Old 11-20-2009, 12:58 PM   #7
altink
My Ride: 99 328i
sway bar links are also smthin that makes that kind of noise, so have a look at them aswell, gl
328i auto
95 Caprice 9c1
03 Tahoe LT
01 GSXR 1000
Life is promised to no one so live it best you can.
altink is offline   Reply With Quote
Old 11-20-2009, 01:00 PM   #8
bmw02ci
My Ride: CI-coupe
Thanks n2Bimmer, good advice!
Old 11-20-2009, 01:02 PM   #9
bmw02ci
My Ride: CI-coupe
Thank you everyone, I will take all these suggestions into action and she will drive nice again soon.
Old 11-20-2009, 03:56 PM   #10
TLM
My Ride: 2001 325i Touring
If you're checking the end links, make sure there's no pre-load on the bar. Pre-load can prevent you from tightening up the end link bolts. You'll end up with noisy, clunky end links that will drive you nuts.
I suspect your car has bad CABs as that's typical noise on rough roads. Easy to change both the bushings and the endlinks since you've got the front up and the wheels off.
TLM is offline   Reply With Quote
Old 11-20-2009, 11:01 PM   #11
bmw02ci
My Ride: CI-coupe
What are the end links and CABs?
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
