Old 11-21-2009, 02:47 PM   #1
zuckuss00
My Ride: The Flesh Machine
Windshield Wiper Fluid Light...?
Hey!
My wiper fluid light has been on forever and im sick of seeing it! Their is a leak in the reservoir tank which i dont care to fix because i NEVER use it and dont want to fork out the money for a new pump. Plus my car is always clean, in the 3 years iv owned my e46 iv used it like twice. Is there anyway i can get the light off my dash without filling the reservoir with fluid? I noticed the windscreen washer system has 3 fuses: 49,52,59. Would pulling one of these stop the light?
Thanks!
ModBug Diagnosed...
zuckuss00 is online now   Reply With Quote
Old 11-21-2009, 03:02 PM   #2
I*do*Werke
My Ride: three two three
The leak is caused by a valve being stuck open in the washer fluid pump. just get a new pump and fill the reservoir with fluid. changing the pump is an easy DIY.
http://cgi.ebay.com/ebaymotors/BMW-3...s#ht_745wt_857
(I bought the pump from this exact seller and it still works just fine)
all together less than $20
I wouldnt know about the fuses though
Rims Coming Soon!
I*do*Werke is offline   Reply With Quote
Old 11-21-2009, 07:20 PM   #3
Chriztofor
My Ride: 2000 323i (Auto)
^when you change the pump also replace the grommet, it costs a couple of bucks. This link is for illustrative purposes only http://www.amazon.com/OES-Genuine-Wa.../dp/B001G6MOG0
For most BMW problems start off by reading your codes using a peake research tool. Note, as mentioned by other members, although Autozone checks your codes for free they use a generic OBDII tool that does not have the BMW specific fault codes.
Chriztofor is offline   Reply With Quote
Old 11-21-2009, 07:33 PM   #4
alwaysbored786
My Ride: 02 330ci, 3 pedals=)
Send a message via AIM to alwaysbored786
pull one fuse at a time and see if it takes teh light away, if it doesnt, then just put it back
Depo Corners & Sidemarkers, CCFL AE's, Yellow fogs, M3 Mirrors, M3 trunk lip spoiler, M3 Seats, Smoked Eagle Eyes, Shadow trim & kidney's, E46 fanatics Decals =)
**Muz Khan**
Originally Posted by MClarke View Post
Whoops, sorry. I didn't mean to post this thread twice! I thought the first one got lost somwhere in the interweb.
alwaysbored786 is offline   Reply With Quote
Old 11-21-2009, 07:36 PM   #5
Chriztofor
^yeah but read the fuse labels, on the piece of paper below the fuses, to make sure that the fuse doesn't also control something else ie: fuel pump.
Old 11-21-2009, 07:53 PM   #6
zugellos
My Ride: '02 330i & '06 R6
I had the same problem too.
And like you zuckuss00, I didn't want to bother with replacing something I wasn't going to use anyways.
So this was what I did; sorry no pics:
- Take the entire reservoir out of the car; I think there was only 1 fastener that held it in.
- As you're taking it out, make sure to temporarily disconnect the 2 cables and hose.
- Empty all the water out of the reservoir.
- Take a treble fish hook (3 hooks-in-one) and tie a fishing line to it, roughly 2 feet of it.
- With the cap of the reservoir open, look inside and locate the vertically sliding mechanism that senses the fluid level.
- Take the fishing line with the hook and slowly drop it in.
- Lower the hook to the bottom-side of the sliding mechanism and hook it.
- If done properly you should be able to pull up on the string and one of the 3 hooks would still be stuck on the bottom of the sensor.
- Keep the line pulled tight.
- All you do now is tie the string that is pulling up on the sensor to the hinge of the the reservoir's cap.
- Close the cap.
- Reinstall the reservoir, connecting everything back into place.
And voila! The sensor light should no longer be a problem.
zugellos is offline   Reply With Quote
Old 11-21-2009, 08:14 PM   #7
Chriztofor
^so there must have been a reason why you didn't just remove a fuse?
Old 11-21-2009, 11:00 PM   #8
zuckuss00
- Close the cap.
Cool thanks! i was thinking of something along that line! but id like the try to fuses before i go fishing!
ModBug Diagnosed...
Old 11-21-2009, 11:10 PM   #9
Hartman
My Ride: 2000 323i
You can get a cheap pump at Autozone for $12, you just have to splice into the existing harness.
Hartman is offline   Reply With Quote
Old 11-22-2009, 12:39 AM   #10
bigpaulie69
My Ride: 1997 BMW M3
honestly no offense to the op but if your bothered by the light and not willing to spend the $20 that it will cost to fix i would recommend getting rid of the car because you will be running into WAY more expensive problems that will require multiple things to be replaced just to get rid of a light. Not trying to be disrespectful at im just saying this isn't a honda civic where you can get away with half the stuff not working and driving around with no bumper.
1997 E36 M3
MODS: AA Diff. Support, UUC SSK, Euro headlights, UUC headers, UUC exhaust, ACS TYPE III replica Rims. Porsche "meteor Gray" paintjob, smoked lights, UUC RTAB, UUC RSM's
Soon: Suede headliner, Alcantara euro steering wheel, ACS interior, Supercharger.
bigpaulie69 is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
