Old 11-25-2009, 04:38 PM   #1
burntass
burnt ///Member
burntass's Avatar
My Ride: an e46 cabrio
strut bar install
I'm trying to put on my strut bar, but I'm having a little trouble getting one of the brackets into the area where the battery terminal outlet is (the left side). I am supposed to jam it in there? or remove the battery outlet first?
burntass is offline   Reply With Quote
Old 11-25-2009, 04:41 PM   #2
Many330i
My Ride: 330i ZHP Silver
Try moving the battery outlet to the side (towards the w/s) and wiggle the strut bar underneath..
Many330i is offline   Reply With Quote
Old 11-25-2009, 04:49 PM   #3
andrewboi
My Ride: not very fast
yup - thats exactly what I had to do too. There is sort of a clip or something that comes off, and allows you to take the battery part off
andrewboi is offline   Reply With Quote
Old 11-25-2009, 04:59 PM   #4
albertbmw
My Ride: 330i M Sport
Had the same problem installing my Strong-Strut. Only way to do it properly is to lift up the rubber seal behind the battery terminal, under which you'll find a plastic bracket (this secures the terminal). Holding this in place is a small plastic "grommet" which needs to be removed. After removal, simply lift up the whole bracket, place the top plate of your strut bar in position and bolt down. Then replace the plastic bracket and rubber seal. Job done!
albertbmw is offline   Reply With Quote
Old 11-25-2009, 05:07 PM   #5
Chris C
My Ride: 2001 325Ci
+1. Nice to read from another person that has a Strong-Strut brace.
Chris C is offline   Reply With Quote
Old 11-25-2009, 05:50 PM   #6
albertbmw
Thanks. I was blown away by the craftsmanship and finish of their brace, and their guy Paul is really friendly and professional. Just had to get myself one shipped to the UK, well worth the price!
Old 11-25-2009, 11:45 PM   #7
jzwu
My Ride: 2005 BMW 330Cic
A little surprised that the Strong-Strut bar needs modification of the battery + terminal. My cheap Rotora strut bar has the cut-out on the left bracket and it fits perfectly.
jzwu is offline   Reply With Quote
Old 11-25-2009, 11:49 PM   #8
ChrisTKHarris
My Ride: 325Ci
Now there's three of you. Mr_Mikes7 has one too.
It shouldn't. Mark's didn't need modification IIRC.
-Chris
ChrisTKHarris is offline   Reply With Quote
Old 11-26-2009, 02:09 PM   #9
burntass
burnt ///Member
burntass's Avatar
grommet
the "grommet" is circled in green -- it's not a torx screw, so I pull real hard with a screwdriver.. will it pop out and not break?
Old 11-26-2009, 02:43 PM   #10
s3th
My Ride: 330ci
yes much easier to slide the battery up.
You can just call me seth.
Buy Giftcards HERE!
Originally Posted by slo323ci View Post
This is definitely not a joke of Bimmerseth54... he's the sexy model on the hood :drool:
Originally Posted by DME46 View Post
E46fanatics is serious fvcking business. :rofl:
New name, same person (bimmerseth54)
s3th is offline   Reply With Quote
Old 11-26-2009, 02:48 PM   #11
TKC
My Ride: 2001 330cic
Send a message via AIM to TKC
There is a "pin" to that part you circled, it's on the back. Pull the pin out from the back and that whole push pin will come out. Then the battery terminal will slide up and out.
EUROPROJEKTZ - Co-Director, NorCal Chapter
TKC is online now   Reply With Quote
Old 11-26-2009, 02:50 PM   #12
burntass
burnt ///Member
burntass's Avatar
will give that a shot. thanks
Old 11-27-2009, 02:47 AM   #13
albertbmw
When I bought mine, it came with instructions that specifically explained that the terminal needed to be moved to enable fitment.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
