Old 11-26-2009, 01:28 AM   #1
Castel101
My Ride: 2000 BMW 323i
Question How do you reset a CEL (Check engine soon) light?
I know you can reset the CEL with a Peak Scanner but I don't have one right now. I've searched too but all I can find is how to reset the oil service check. Autozone would read it bt they won't reset it, at least in Oregon? Is there a way to do it? A sequence, shorting a couple of pins or something? Also I know what the code is and it's fixed. Thanks for any help!
2000 BMW 323i
Castel101 is offline   Reply With Quote
Old 11-26-2009, 01:43 AM   #2
m1356guy
My Ride: has orange corners
once you have one you'll know
-Spencer
m1356guy is offline   Reply With Quote
Old 11-26-2009, 02:31 AM   #3
Castel101
Hmmm... Have what? The CEL on? I have it right now...
2000 BMW 323i
Old 11-26-2009, 02:36 AM   #4
m1356guy
once you have a peake tool, arent u gonna buy one?
-Spencer
Old 11-26-2009, 02:40 AM   #5
mkodama
mkodama's Avatar
You are mixing up the "Check Engine Light" and "Service Inspection" message. I cannot tell what you are talking about or what you need help with.
MY 330i FOR SALE - $4000 WITHOUT WHEELS
Downloadable E46 Owner's Manual - BMW Oil Info - Find Any BMW Part Number - Lookup Any OBD2 Code
For Sale:
AUTOart and UT Models die-cast model cars - Goodridge Stainless Braided Brake Lines - Black Coupe Sports Seats (Used)
PM me for details for any of the above.
Old 11-26-2009, 03:04 AM   #6
bumere46
My Ride: 2004 330ci
I think you have to hold the odometer button for 30 secs or something like that...
if you search u'll find
bumere46 is offline   Reply With Quote
Old 11-26-2009, 03:53 AM   #7
Castel101
I meant that all I could find was how to reset the service inspection. I want to reset the Check Engine Light/Service Engine Soon. Clear it so that it doesn't show up on the instrument cluster anymore.
2000 BMW 323i
Old 11-26-2009, 03:54 AM   #8
Castel101
Thanks for the replies so far though...
2000 BMW 323i
Old 11-26-2009, 04:42 AM   #9
mkodama
mkodama's Avatar
Ahh, for the SES/CEL you need to plug it into a code reader and clear the codes. The service inspection message can be reset with the button on the instrument cluster, but SES/CEL require a scanner/computer to clear them. So you will either need to have the people at autozone clear the codes, have an independent mechanic clear the codes, or buy a Peake code tool and use that to clear the codes.
To my knowledge there is no pin-shorting method to clear a SES/CEL.
For Sale:
Old 11-26-2009, 09:02 AM   #10
pjo33us
My Ride: 03 330xi
Ummm, I have the same issue... Any thoughts on just disconnecting the battery for 20-30 minutes and "re-booting" the car? I am throwing an MAF code... I have cleaned it and want to figure out if I am ok now.
Sorry for the highjack, but could a K&N filter be causing the MAF code?
pjo33us is offline   Reply With Quote
Old 11-26-2009, 09:04 AM   #11
Nineteen89
My Ride: Has 3 Pedals!
Clearing before the sell are you?
jk
Nineteen89 is offline   Reply With Quote
Old 11-26-2009, 10:24 AM   #12
Pir4t
My Ride: 323i -98
It can be the cause of the maf going bad , but it wont make you see the code directly.
As for op : get a ELM327 and some odb software and use your laptop to see / clear codes . it's awesome !
Pir4t is offline   Reply With Quote
Old 11-26-2009, 11:56 AM   #13
ixtoxi
My Ride: 2002 330xi
If the problem causing the CEL has been corrected, the light will go out after a number of starting cycles. Some go out after 30 (I think), some require more cycles to clear.
ixtoxi is offline   Reply With Quote
Old 11-26-2009, 12:59 PM   #14
TKC
My Ride: 2001 330cic
Send a message via AIM to TKC
unplug ur battery for 20 min to an hour.
it will clear it but if whatever is kicking it on is still causing issues, it will come back on soon.
EUROPROJEKTZ - Co-Director, NorCal Chapter
TKC is online now   Reply With Quote
Old 11-27-2009, 11:46 AM   #15
pjo33us
My Ride: 03 330xi
Tryed this...did not clear the codes... Also, removed the MAF and cleaned with MAF cleaner. I will drive it for a couple weeks and see if the codes clear themselves or if I need a new MAF...
Old 11-27-2009, 11:54 AM   #16
GNENSEC
My Ride: 330i Sport
I have the K & N CAI mine has worked great, I heard the oil in the filter might adheare to the MAF, clean it you'll be good.
I'm thinking about buying an AFE dry filter, I'm checking to see if the end fitment is the same size.
Everyday is a good day when you can hit 100mph+, on the way to work!!
DSC: OFF SPORT: ON
2001 M5, 740i Sport SOLD, 1995 M3 SOLD, 1991 318is, 325ix SOLD, 1980 633Csi SOLD.
GNENSEC is offline   Reply With Quote
Old 11-28-2009, 04:16 PM   #17
mujjuman
My Ride: E46
Just tell autozone to clear the codes
mujjuman
2003 BMW 325xi 5MT
Jet Black, ZSP, ZPP, ZCW
mujjuman is offline   Reply With Quote
Old 11-28-2009, 04:24 PM   #18
e46beamer01
My Ride: 2001 E46 325Ci
Send a message via AIM to e46beamer01
^ or go to adavanced auto
01 E46 BMW 325Ci (Current)
99 EK Civic JDM B16 Hatch (Current)
98 EJ8 Civic Coupe B20/Vtec (Current)
96 EJ6 Civic Sedan (Daily Driver)
03 Yamaha R1 (Current)
e46beamer01 is offline   Reply With Quote
Old 11-28-2009, 06:16 PM   #19
Megalocnus
My Ride: 09/98 323i ZSP/MT
If the ses light is bothering you, just open the cluster and stick a black tape over it.
Kidding of course. Every time the ses is on, you want to know why. Buy a scanner, bring it to aurozone, to a mechanic, whatever.
Megalocnus is offline   Reply With Quote
Old 11-29-2009, 03:33 AM   #20
Castel101
Hey guys, thanks for the replies. Disconnecting the battery won't work even if the issue is fixed, I did it. Also I found out that at Autozone they used to do it a long time ago but not anymore because of liability issues with the DEQ/DMV testing or whatever. What they told me though is that you can go to Autozone, put $150 as deposit on your credit card and they will lend you the scanner! I used it for 15 mins and then returned it, you get the deposit back so it is completely FREE. My codes are cleared and the CEL is gone!
Unfortunately after a day the CEL came back... I replaced the lower and upper intake boot, cleaned ICV and DISA and didn't help, issue is still there. I'll have to take it to the mechanic on Monday as it can be a number of things, I don't have a smoke machine to test for vacuum leaks, etc... I had codes P1188, P1189, P0170 just FYI.
Thanks for your help!
2000 BMW 323i
cel check engine soon
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
