Old 11-26-2009, 01:24 PM   #1
Bimmer330cibro
My Ride: AW 330ci
Send a message via AIM to Bimmer330cibro Send a message via MSN to Bimmer330cibro
Changing Trans and Diff fluid out of 01 330 MT.
Well i searched but i couldnt find a DIY. Anyone got the DIY for changing these fluids? Preferably with pics and stuff, thank you
Bimmer330cibro is offline   Reply With Quote
Old 11-26-2009, 01:51 PM   #2
bishop1977
My Ride: 04 330i ZHP S/C
1.buy fluid for diff and trans and hand pump fill jug
2.lift car up
3.unbolt refill bolt FIRST then unbolt drain plug
4.drain fluid and put drain plug back in
5.pour fluid into jug
6.fill fluid through refill plug
7.put refill plug back in
8.clean jug out with brake cleaner and wipe dry
9.repeat for second item
bishop1977 is offline   Reply With Quote
Old 11-27-2009, 06:36 PM   #3
My325XI
My Ride: 03 325XI Sprt Prem
http://www.bmw325i.net/maint_rear_diff_fluid.shtml
http://www.bmw325i.net/maint_tran_fluid.shtml
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 12-04-2009, 05:49 PM   #4
corstad
My Ride: 99 328i
Is anyone else getting site not found when trying to access bwm325i.net? The site had a couple of very good DIYs, these 2 especially.
corstad is offline   Reply With Quote
Old 12-04-2009, 07:46 PM   #5
taibinhvuong
My Ride: E46 99' 328i
2.lift car up
If you follow the procedure above, big chance that you will burn out your expensive transmission because it at least short of 1.75 quarts tranny fluid. So after procedure 7 above you need to follow these:
7_1. put the car up level on jack stands.
7_2. Start the engine.
7_3. unbolt filler plug.
7_4. pump some more fluid (about 1-1/2 to 2 quarts) into filler plug until it leaks back out.
7_5. Let the engine idles for about 20 to 25 minutes to warm the tranny up if the car had just not yet driven.
7_6. Move the tranny shift lever through every gear and halt about 2 secs at each gear including reverse.
7_7. Recheck the fluid at the filler plug, if fluid stops coming out then pump in little more until the fluid just slowly leaks back out.
7, 8. Follow the procedure above.
For diff. fluid change, you can follow bishop1977's procedure, but need to make sure that the refill fluid slowly leaks back out before you put the plug back in. You may not need to jack the car up if you can partially lay yourself underneath the back side of the car and reach your hand out to the diff. box. I'm not a big guy and my car wasn't lowered so I did that with ease.
taibinhvuong is offline   Reply With Quote
Old 12-04-2009, 09:22 PM   #6
taibinhvuong
No good, me too!
Old 12-05-2009, 10:25 AM   #7
corstad
My Ride: 99 328i
Thanks. What I liked about that site is it stated exactly what tools were required for the DIY.
Old 12-05-2009, 03:00 PM   #8
verb
My Ride: e46
I was just searching for these DIYs the other day too. They won't load for me either.
verb is online now   Reply With Quote
Old 12-05-2009, 03:50 PM   #9
Miko_10
My Ride: 330i Steel Grey, MT
MT fluid
http://forum.e46fanatics.com/showthread.php?t=491209
Diff fluid, try in here
http://forum.E46Fanatics.com/showthread.php?t=519743
MOD List:OEM M Tech 2 front and rear bumper:18x8.5 VMR CSLs all around:Always broken CCFL Angel eyes:OEM clears all around:20% tint:M3 Steering wheel:Replica M3 rear spoiler:DICE Unit(stealth tray mod):Vinyl wrapped and custom painted matte aluminum interior trim:Big Boy clutch stop:ZHP shift knob.
Miko_10 is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
