Thread Tools Search this Thread Rating: Thread Rating: 20 votes, 4.95 average.
Old 04-27-2017, 08:12 PM   #3341
fipse
My Ride: e46 330ci
Originally Posted by okeefe325ci View Post
so lets say if i am in fact already in sw0056 then no boot mode of the ecu is required and i can directly modify my car for eu2 and obd readiness via the 64kb file via tunerpro and galleto? if i am 0066 then i must run bootmode and do a full 512k flash? then the checksums will need to be cleared if i work with the 64kb file only via winols?but not if i do the xdf since that includes the ews delete as well as deletes the need for checksums? i am still very new to this ecu business so i apologize for stupid questions beforehand.
Yes sir...
Checksum correction* is only needed if you don't use daniels 512k File.
-f
*No need for win0ls. CS-Tool download is on the wiki (http://ms43wiki.com)
fipse is offline   Reply With Quote
Old 04-27-2017, 08:16 PM   #3342
okeefe325ci
My Ride: 325ci
Originally Posted by fipse View Post
Yes sir...
-f
cool im not as far off as i believed. youve been a great help fipse. one last thing is where do i find a 64kb euro2 bin or file? is it in the wiki and im just being blind? also would it be a .bin or xdf?
okeefe325ci is offline   Reply With Quote
Old 04-27-2017, 08:22 PM   #3343
fipse
My Ride: e46 330ci
You have to build/use you own.. No bin there..
http://ms43wiki.com/index.php/Main_P..._Configuration
Old 04-27-2017, 08:26 PM   #3344
okeefe325ci
My Ride: 325ci
i see, "euro2" or catless w sap and post o2 delete is achieved through lamda sesnsor configuration by myself. much appreciated fipse i hope to be posting my results this weekend. eventually ill dive into all that fun stuff like burbles and launch control (:
Old Yesterday, 09:32 AM   #3345
Josie8888
My Ride: 330ti
After some tune, and diferents configurations, always, or about 90%, my launch control fail... I have set up at 3500 aprox, and it bounce about 3500-4000 for an unknow reason, some times, one bounce pass the 4000 limit, and the LC is desactivated... Clutch swich is ok, ABS sensors are ok.... Only i have oil sensor/temp damaged, this may be the reason? ( I replace in the next oil service )
00:16 ->
Josie8888 is offline   Reply With Quote
Old Yesterday, 11:47 AM   #3346
E46Dreamz
My Ride: e46 330i
Anybody got any ideas to make exhaust pops work nice with turbo setup? The standard way will not work well because of piping configuration
E46Dreamz is offline   Reply With Quote
Old Yesterday, 01:29 PM   #3347
cwarel
My Ride: 330ci coupe
Originally Posted by Blu302 View Post
The first thing to check is the MAF settings. Either the data in the DME is wrong, or you have an electrical problem.
It is reading high because it is either getting a high voltage from the sensor, or the voltage in the MAF table tells it this high value.
Checked everything , didnt find a problem , everything looks good
cwarel is offline   Reply With Quote
Old Yesterday, 06:08 PM   #3348
stefm5
My Ride: 2001 530i
i completed yesterday the maf conversion and it reads around 18kg/h and 120mg/stk at idle.
stefm5 is offline   Reply With Quote
Old Yesterday, 11:57 PM   #3349
Blu302
My Ride: '98 E46 323i
What is the MAF table set at?
Do you have a pic?
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Old Today, 08:36 AM   #3350
cwarel
Do you have a pic?
Yeah ill post pics of afr. load . maf readings or i can just tell you .RS4 MAF , isaless.
Idle 880 rpm
AFR - 9~10
Load ( always goes crazy from 300 to 1389 )
Maf readings over 100 kg/h
Maf located on pressure side ( maybe i should move it to the intake side of the turbo)
Anyways MAF tables used from RS4 maf thread
EDIT: Found a vacuum hole in the intake manifold , fixed it , started the car new readings
MAF 50kg/h
Load 325 +-
AFR 10
Rate This Thread
