DYNAVIN N6 Multimedia GPS System, New for 2015 - Page 38 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 261 votes, 5.00 average. Display Modes
Old 05-14-2017, 01:05 PM   #741
tczwoju
My Ride: BMW,VW
Originally Posted by VpointVick View Post
Because you've got the camera power wired to the reverse lights it'll only be powered when you're in reverse, so if you don't have the car in reverse when you hook it to the Vid AUX in to test it won't display anything. Conversely, if you don't have the green reverse wire connected to a source that's triggered by the back up light switch then the head unit won't know to look for the camera.
One of th eAudi forums might be a better place to try and find out what color wire to look for to tie into for a trigger, but worse comes to worse you can always run a wire forward from the reverse light itself, where you tied into to power the camera, and connect that to the green wire from the head unit. Many video cables for backup cameras already come with a wire built in for this very purpose so you only have to have the one cable routed forward for both functions.
Hi,
I have already this cable wired in place.The only wire I cannot figure out is "reverse detecting green" as in Dynavin A5 wiring seems to be different fron Dynavin generally and I dont have schematic for Dynavin Audi A5 harness.
I will try few others but dont want to burn anything.
Cheers
Woj
tczwoju is offline   Reply With Quote
Old 05-14-2017, 01:23 PM   #742
VpointVick
My Ride: '03 325iT Mysticblau
Originally Posted by tczwoju View Post
Hi,
Cheers
Woj
Connect the red wire on that cable to the positive side of the reverse light at the back. the same place that you're getting power for the camera, then connect the other end to the green REVERSE wire on the Dynavin.
You do have that one extra wire coming off of the A harness, right?
VpointVick is offline   Reply With Quote
Old 05-17-2017, 10:43 AM   #743
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
He probably does not have a reverse wire since he has an audi.....most of the audi dynavin units did this via the canbus.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 05-17-2017, 04:12 PM   #744
tczwoju
My Ride: BMW,VW
Guys,
I have already had this cables connected and there was no picture.I have a replacement camera coming to double check if this is not a camera problem.
I will report back once I figure it out.
Old 05-19-2017, 01:57 PM   #745
tczwoju
My Ride: BMW,VW
Guys,
Okay,
Secret was in grey loose wire called 360 on the back of Dyavin A5 unit. I would never guess that. Now camera is working nicely but another problem is that reverse light power doesn't like to power up camera, voltage drops as soon as engine starts, camera goes black. So I had pulled a power for camera from cigarette lighter fuse and use reverse power only for trigger unit and it works well.
Woj
Old 05-19-2017, 02:12 PM   #746
P_Monty
My Ride: 330Ci Msport
I wonder if you've got a bad connection on the reversing lights?
P_Monty is offline   Reply With Quote
Old 05-19-2017, 02:49 PM   #747
tczwoju
My Ride: BMW,VW
HI ,
no problems with bad connection.It is know issue with Audi cars,many people have the same problem.I guess it is due to low power provided to the reverse lights only.Some people have to use a relay.To much electronics.
Cheers
Woj
Old 05-19-2017, 07:42 PM   #748
Hisdem
My Ride: 2004 M3 Convertible
Update on my issue with the BAVSOUND speakers: the issue seemed to be software related. Did a "factory reset" through the N6 unit, no problems have occurred since. In fact, SQ has gotten considerably better. Many thanks to Jeff for quick and efficient support.
Hisdem is offline   Reply With Quote
Old 05-26-2017, 09:32 AM   #749
J&T Distributing
My Ride: BMW
Old 05-27-2017, 01:08 AM   #750
sj84
My Ride: 2000 323i
Hi all
I'm new so please forgive me if this is an inappropriate thread for this.
I recently installed a brand new N6 (1.3.0) in my 323 and have found a couple of irritating glitches. In reading the posts I seem to be alone so I wonder if I've installed something incorrectly:
1. Whenever the unit powers on it immediately starts playing either radio or from the SD card regardless of if it was playing when powered down. Is the unit being reset every time?
2. Related to above and by far the most irritating. I installed a reversing camera too, powered by the reverse lights but if used when the unit is powered off the picture comes up fine but it insists on playing the last thing played with no way to stop it (volume and pause/play inoperable) and is only stopped by taking it out of reverse, powering on, then stopping the automatic playing of music (above) THEN going back into reverse. Any ideas?!
3. Bought the DVB radio unit and it's a bit rubbish, drops every 5 secs for 1 sec despite having a full DVB signal icon?
4. Normal FM radio very poor-looked like there were 2 input cables in the dash, tried both and both were poor. Does it need some sort of amp?
5. Anyone know of a quick way to restore the Satnav speaking volume if you accidentally turn it down? The 2 different volumes are operated by the wheel controls but if you turn the voice instructions down it's impossible to bring them without rooting around in the settings?
Finally, if you install the iLink does that mean you can't use the DVB unit? Anyone got experience of the TV DAB vs normal radio DAB?
Thanks!!
Sam
sj84 is offline   Reply With Quote
Old 05-27-2017, 08:33 AM   #751
mjpgolf1
My Ride: 00 328i,05 745,03 X5
I'm sure all of this will be resolved and will be made right. My Dynavin N6 is absolutely awesome and has worked flawless since install. I can't help with all your issues but concerning the navigation voice volume I think you can adjust the voice volume on the regular volume knob while the nav is speaking to you. Try loading in a destination and as soon as the voice comes on adjust the volume knob and it should default to adjusting the navigation voice. If not there are several different areas in all the settings menus both for the unit itself and the navigation program where volumes can be adjusted. It took me a while before I got everything dialed in just because this unit does so much so just be patient with it and you will love the N6. Hopefully you bought your unit from a reputable source so you have good support but regardless Jeff will no doubt be along here to help answer any questions. Good luck.
mjpgolf1 is offline   Reply With Quote
Old 06-01-2017, 11:50 AM   #752
J&T Distributing
My Ride: BMW
Sam, read the FAQ on our website, you have a powered antenna, read the info about that. Update to the newest firmware on both your dynavin and your DVB box (speak to your dealer for this, its not something we have in the US). The reverse thing is a known bug, its being looked into. There is a nav volume setting in the latest firmware or turn the knob back up when the nav is talking.
Old 06-01-2017, 12:34 PM   #753
VpointVick
If I turn down the Nav volume by accident I just wait for the next direction it gives and turn it back up. The steering wheel volume buttons work on Nav when it's active, in both directions.
Old 06-01-2017, 03:20 PM   #754
J&T Distributing
My Ride: BMW
Heads up!
We will be at the west coast Bimmerfest at Auto Club Speedway in Fontana this weekend, booth #313 in the Vendor Alley. Come by and see us, product on display, show only specials, blah, blah, blah...
http://www.bimmerfest.com/bmw-events/Bimmerfest-2017/
Old 06-05-2017, 05:34 PM   #755
sj84
My Ride: 2000 323i
Sam, read the FAQ on our website, you have a powered antenna, read the info about that. Update to the newest firmware on both your dynavin and your DVB box (speaker to your dealer for this, its not something we have in the US). The reverse thing is a known bug, its being looked into. There is a nav volume setting in the latest firmware or turn the knob back up when the nav is talking.
Hi Jeff
Thanks to you and the others for the help.
Dynavin looking into the reverse and auto play thing so cheers.
Radio FM now fixed, actually used an OEM adapter that negated the need to alter the air box at the rear AND immediately improved signal (61126913955).
Haven't heard back on firmware update for the DVB box itself, but the N6 is on the newest (1.3.0). Really is odd it records a strong signal bar in the top left of the screen and then can't pick up a station or drops all the time en route. Even installed 2 screen aerials (dynavin supplied non powered and aftermarket powered) but no difference between the 2.
Cheers all on satnav, found the menu for the satnav voice volume, just a shame it's buried!
S
Old 06-23-2017, 11:54 AM   #756
J&T Distributing
My Ride: BMW
Old 06-23-2017, 12:35 PM   #757
VpointVick
I bought mine used so have no dealer to speak to, and it's started acting up (has frequently displayed a white screen with colored vertical lines at startup preventing boot, and doesn't respond to holding the mode button to reset. A couple of times it has sorted itself out and rebooted correctly while I was driving, but also a couple of times it has slowly gone to the screwed up screen and become unresponsive after a proper bootup. When it's done that the radio will continue to play but I can't change inputs or even the volume) and I'm wondering if there is a direct help line or way to send it in for service.
Old 06-23-2017, 12:40 PM   #758
J&T Distributing
My Ride: BMW
Email me, contact info is on our website.
Old 06-27-2017, 02:17 AM   #759
oregonbmw
My Ride: 2004 330cic
I just purchased an E46 that has a Dynavin system installed. I have been trying to delete the old owners google account and update the firmware to the latest to no avail.
First of all the firmware. I suspect that the system maybe on an old firmware, perhaps original and have downloaded the latest 1.3.x and put it on a micro-SD card and inserted it into the system. The problem I am having is that I cannot find any where in any menu the info or update screens. I can't find it under the Dynavin Settings menu/area nor any info item. I did stumble on a kind of hidden menu when you swipe cross the top of the screen. But nothing to do the firmware install. I also looked into the android settings menus, but the update section under the about says that things are up to date and doesn't give me any install options.
I have spent hours trying to figure out how to install the firmware update. I haven't been able to find any info or display or menu that will show me the dynavin version that is currently on the system.
Settings Menu Image:
Setting Extra Menu:
Then I also tried deleting the original owners account. I have added a second account. But when I go to remove the original owner's account it says that it is required by some applications and I need to reset to factory defaults under the privacy menu. So I do the reset thing, a message appears that it is erasing the date, the Dynavin system reboots but when things come back up, I find that the original account is still there on the system.
Image of account that can't be removed:
Image of system resetting, supposedly erasing account:
Any help or clues would be greatly appreciated. I have spent quite a bit of time on this and I have a fair amount of experience with android phones.
oregonbmw is offline   Reply With Quote
Old 06-27-2017, 06:32 AM   #760
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
What you have is not an N6, but an earlier Dynavin model. The N6 is not an Android model. Search for Dynavin Android and you should be able to find some clues what model you have. If you can figure out through the menus how to access system information, you should be able to figure out what you have and probably find the correct thread on your model.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
