The Showroom
Old 04-28-2017, 08:48 PM   #1
Yachtgoat
My Ride: 2001 330ci
Aibae46td
Mods, Feel free to change my thread name it was supposed to be 'AIBAE46TD" with i reference in my "Welcome "Page intro...
The Victim,
2001 330Ci, 9/2000 production. Very solid car, Bought it out of a trailer park in Florida City. Florida.
Everything leaks, the driveshaft blew up on the ride home, but i made it to the shop.
Plan is for a "Florida" street legal track car with A/C and power windows. When i smoke the motor, LS will go in. I used to own an '06 GTO/Monaro, and the e46 is just a better version of the Monaro, which is a copy of an E36?
I'm a pretty solid wrench, so it's a fun car to work on. Stuff is coming apart well.
Biggest repair has been cracked mounting area for the center support bearing. I have cleaned it up and reinforced the area. Welds look like **** but it works. I had a shop I've used before send out the driveshaft for rebuild in Atlanta. It came back with the nicest center support bearing i have seen. will post pics of that.
If someone can remind me how to properly embed pic on this fine forum that would be great!
ID:	654176   Click image for larger version
ID:	654178   Click image for larger version
Yachtgoat is offline   Reply With Quote
Old 04-29-2017, 09:20 PM   #2
Yachtgoat
My Ride: 2001 330ci
Huge day in the Shop today.
Started with massive under car power wash. My Ryobi mini just kills it, I can wash on my shop floor and run my shop vac the whole time and i make very little mess.
I dropped my front cross member earlier in the week so it was easy to get busy and get her buttoned back up. Thanks to whoever i got the tip on the Hazard Frought engine hanger deal.
-Dropped pan
-Cleaned that nasty bitch
-Examined bottom end. Looks good to me, pistons are clean, its just typical 160,00 mile + miles "gold".
-Oil pump looks good for now. Marked it so when it blows up i can Be all CSI on it.
-Front and rear main seal are not leak suspects at this time.
-Torqued it all back up with a fresh gasket. the old one was TOAST.
-Pulled the Oil filter housing.
-another round of cleaning
-examined CCV, it is intact, will run it and see.
-Reinstalled OFH.
-Dressed the front of motor: New water pump w/ ECS pulley, New LuK-30 pump with bracket and pulley from ECS, New tensioners and idler pulleys and Conti belts. And Ditto A/C.
-Dropped the exhaust manifolds. I was kicking myself for loosing my 1/4" drive air ratchet! The only snag was getting the wires out for the aft 02 sensors, they were hung up at the top aft of the motor. Nice thing about having the motor hanging is you can drop it to the sway bar and get to stuff.
So Next up is:
-Ebay sourced E36 stock exhaust manifolds. Should i get coated?
-Bimmerworld sourced SpecE46 downpipe.
-Vorshlag "pussy" motor/trans mounts
-Rebuilt "Yellow" rack and TRE's from the Rack Doctor (car had yellow when i bought) with all new hoses, res[IMG][/IMG] and delicious Castrol juice.
-New left LCA and Powerful aft bushings (right one is new)
-Shifter Rebuild. Car came with one of those shitty looking e-bay $30.00 shifters. I'm gonna throw it in with some other pieces and see how it goes. I think the 3rd synhcro is toast anyway.
-Rebuilt Drive shaft from my local guy via a shop in Atlanta. The CSB is burly.
-Cooling system refresh.
-Remember to put oil and water in.
-Tranny fluid change.
Hopefully after that i'll slap some tires on and drive it around a bit....
Post tear down clean
you, its bolted together, for now
All cleaned up round 2
And done for the day
Old 05-03-2017, 03:39 PM   #3
Yachtgoat
My Ride: 2001 330ci
So I got my Ebay sourced E36 manifolds, which as it turns out are OBD2 manifolds.
So off to a friends for some fill welds and then another friends mill.
No biggie.
Old 05-03-2017, 11:02 PM   #4
BBBoy323i
My Ride: 01' 325ci
Nice project
BBBoy323i is offline   Reply With Quote
Old 05-06-2017, 09:29 PM   #5
Yachtgoat
My Ride: 2001 330ci
Another Saturday, Another day in the Shop!
I took it easy this week as the previous Saturday i retweaked my tweaked knee and got it good and swollen. 55cc's of fluid out and some Cortisone in and all good! So mostly i just picked up parts and got my exhaust manifolds welded at one shop and milled flat at another.
So Today:
-Installed a bunch of studs in the head as my car was missing a few (like half). Yes i know its overkill to have all 100 studs, but its easy enough. Bolted up the manifolds with no hassles, my new 1/4' mini air ratchet made it a cinch. Downpipes fit perfect as well, nice job Magnaflow and Bimmerworld!
-Bolted up the new Vorshlag "Pussy" mounts to the front crossmember and bolted it up. Yes i reused the old bolts, yes I torqued them. I will get some new ones. easy enough to swap. The engine dropped right down perfect on the mounts. Finished up by swapping the trans mounts in also. Man, the motor is not going anywhere now, holy crap, STIFF!
-I made a little custom braket to hold the O2 sensor connectors and keep all the wires happy. Not sure if I'm supposed to plug in a sensor in the bung on the end of the downpipe.
That was it, tomorrow Power Steering and LCA and LCAB install and hopefully the driveshaft and shifter, and, and, and....Oh, and do the heads on my buddies classic Bronco and start an FI setup on that......
You have to have this book, yes it's $100, but it is priceless
[IMG] photo IMG_0258_zpsni2fsnbu.jpg[/IMG]
All the goodies
[IMG] photo IMG_0256_zps5ixrru6b.jpg[/IMG]
Studs...
[IMG] photo IMG_0273_zpsajdd6xda.jpg[/IMG]
bolted up.
[IMG] photo IMG_0276_zpssgpmkabx.jpg[/IMG]
Trans mounts
My little bracket
[IMG] photo IMG_0282_zpshjsy3jpm.jpg[/IMG]
Old 05-06-2017, 10:15 PM   #6
avantgarde
My Ride: 2001/2005 325xi A/M
looks promising.
avantgarde is offline   Reply With Quote
Old 05-16-2017, 10:59 AM   #7
Yachtgoat
My Ride: 2001 330ci
More work DUN,
I took a bunch of pics but photo bucket is awful now and i haven't taken the time to source new so i can embed. I'll thro some thumbs in at the end.
So A Major Thrash 2 weekends ago saw the car much closer to the driver it became this last Saturday. It also saw us get the heads on and off my buddy sick 302 in his classic bronco, and running properly again.
Saturday
-Bolted up the rack and all new hoses, resivor and filled with juice
-Assembled the cooling system, hoses tank, and got the rad/ac core sitting together correctly which is a challenge. Filled that up and took my time and did a nice long bleed on the system.
-Checked all the vitals and gave it the key and she fired right up! Had some flickering oil light issues, but it just wanted more oil. The oil PSI light switch seemed suspect and a swap out later in the week with a new part solved the issue, would have been easier on the bench however. So it ran great and made loud noises and made the guys in the shop next door come peek!
-Went to Sunfest and got drunk
Sunday
-Installed the shifter
-Installed driveshaft with Buna smashed in heavily around the center support. it all bolted up perfectly. not worried about anything moving in the drive line.
-Fired it up and ran it thru gears, all good no clunks.
-Bolted together and fired the 302, long afternoon rewarded with a easy start up. it was fun walking two noobs (my Captain buddy who owns several nice classics and one of his deckhands) thru a head gasket job on a 40yo small block.
The following week i piddled with the car and got the front end semi bolted together so i could at least drive it around the block.
I had to order a $6 plastic block that holds the lower radiator to the frame, fraking lego cars.
I also made a trip to Redline BMW to see Rennie and pick up a M3 Diff, complete, for $350, can't pass that up...
Saturday i got back on it and bolted up the wheels and took her out for a rip! The tires are destroyed garbage, but OH MY what fun I had Hooning around the neighbor hood (industrial park, in Mexico). we took SOOO much weight out already it just slides around like crazy! 3 rd gear is probably junk but we shall see, and a shorter rear gear is a must! Just kinda piddled with the shop the rest of the weekend. I need to bolt on the lights and bumper and finish stripping the tint. Mostly I need to make the car look like a car so i can get it insured with Grundy and tagged.
To that end i ordered these yesterday: APEX 17'x9" in Anthracite.
And tires this week as well, its gonna be tight in front but i will massage the fenders, no worries.
Also Saturday i did front brake pads on my X5, i figured the old ones had to be hammered, i mean how can that much dust exist and still be pad left, but they were only half done. none the less on went some fresh Akebonos and a half ass wash for the poor DD.
And Tonight is Track Night In America, so heading to the shop now to get ready. What am i running yo may ask? Well my trusty steed, WTF-White Trash Flash, my E70 X5 35ixdrive Msport.
ID:	655158   Click image for larger version
ID:	655159   Click image for larger version
ID:	655160   Click image for larger version
