///M3 Forum
Old 05-05-2017, 02:29 AM   #1
hyungjs
My Ride: M3
SMG failure
I don't know if this happens a lot or not, on my 2003 M3, my smg acts really wired. Like, it works perfectly with no issue when my oil temperature is low, but whenever the oil temperature gets to 210F my transmission warning light will be on, and i cannot engage to any gear but Neutral. Neither my reverse gear. Then i will chill my car for like 1 hour, the oil temperature drops to around 160, the transmission warning light will be gone and the smg will work perfectly again until the oil temperature hits the 210F. Therefore I barely drive my car during the daytime, i only drive at night time it is a pain on my ass, the fault code says hydraulic failure, but its working totally fine at night
If u guys have any idea plz tell me, thanks a lot
hyungjs is offline   Reply With Quote
Old 05-06-2017, 08:20 PM   #2
Topazzar
My Ride: '02 M3
Good luck mate, mine died 3 weeks ago, I have the hydraulic unit out at the moment and about to fit a new Burkhart motor I bought (comes with new, more viscous oil as well). The problem with the motor is the carbon brushes wear out. I guess the cheapest way to do it is just install new brushes into the DC motor if the rest of the unit is OK.
Check the Salmon relay and 40A is always the first thing people should do then get yourself a copy of INPA intalled on a laptop with WINDOWS XP (must be XP) and see what the issue is.
INPA - http://blog.obdii365.com/2017/01/18/...-vista-7-8-10/
Burkhart Motor - https://burkhart-engineering.com/54160en
Motor Installation -
E46 M3|ESS Supercharged|SG V1 Muffler|Silvers Coilovers
Topazzar is offline   Reply With Quote
Old 05-07-2017, 01:25 AM   #3
hyungjs
My Ride: M3
Bruh, im so scared thanks for the suggestions man
Old 05-07-2017, 08:44 AM   #4
Topazzar
My Ride: '02 M3
Well, just completed mine today. New motor on, SMG special tests done in INPA. System primes and all gears work. IT'S ALIVE!!
Mine was stuck in first and hydraulic pressure was zero a few weeks ago, it doesn't sound like yours is catastrophic like that ........ yet!
Old 05-07-2017, 06:26 PM   #5
Hobohunter
My Ride: 2001 M3
I never had issues with my old SMG, even in temps above 110F. I think there was a resistor mod you could wire in that would help in hot temps, but never having to deal with it myself, I can't be sure what it entailed.
Hobohunter is offline   Reply With Quote
Old 05-08-2017, 03:17 PM   #6
doohver
My Ride: M3 E46 Convertible
It is a common issue, check out this forum thread -> http://forum.e46fanatics.com/showthread.php?t=686054_nr_
doohver is offline   Reply With Quote
Old 05-19-2017, 11:26 AM   #7
PhantomX
My Ride: E46 M3
Try the resistor mod and see if that works ( this is just a temporary fix though ) ---> http://forum.e46fanatics.com/showthread.php?t=855810
-1999 BMW M3 Convertible 6SP(Sold)
-2002 BMW M3 Coupe SMG(Current DD)
-2002 BMW M3 Convertible 6SP(Totaled by Red Light runner....that Bastard)
-2004 BMW 325CI Coupe (Sold)
-2003 CBR 600RR (Sold)
-1995 Acura Integra Turbo (Sold)
-1989 BMW E30 (Totaled by sis)
Instagram | Snapchat @ TwinzTurbo
PhantomX is offline   Reply With Quote
Old 05-19-2017, 07:16 PM   #8
buddyz
My Ride: 2003 M3
I have a similar issue-driving in 98 degree heat yesterday and the transmission warning light and service engine light came on, transmission dropped to zero and I couldn't drive it. No previous issues with the transmission. Waited a few minutes and it came back but happened about a dozen times trying to drive it my mechanic. He checked the codes but wasn't sure what the issue is. He called someone else who says "it probably needs a pump" but hasn't actually seen the car. "Take it to the dealer, we don't do SMG work". I let it sit overnight-today drives smooth as ever, no warning lights on dash. But I've called 2 shops and they both say "we cant do that SMG work, take it to the dealer". What's the chances its a real transmission failure vs a heat sensor or Salmon relay or just gremlins? Do I really have to take it to the dealer??
buddyz is offline   Reply With Quote
