Diesel Power from Europe - 330d, 303 ps, 705 Nm (520 lb/ft) - Page 5 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 58 votes, 5.00 average. Display Modes
Old 05-09-2016, 05:46 AM   #81
bimmerimies
My Ride: BMW 330d
Originally Posted by Sergio92 View Post
My clutch E60 218ps works perfect in my 330CD.
I have 600Nm of torque and 275ps.
Only problem is the vibrations in five and six gear with 100% of aceleration.
The next week i am going to change the center mount of transmisión.
All silentblocks are new.
Flywheel E60 is NOT compatible with E46.
Chutch LUK and SACHS its the SAME!
Oh, then that clutch sounds good for me too.
What flywheel you using now?
What parts you mean this "change the center mount of transmisión"?
If gonna take gearbox out from car, what parts you recommend to change new ones?
And what parts should replace/put newer for Drive shaft? (driving 310tkm)
Sachs is more expensive and there seems to be available also Sachs clutch Performance -kits for our car...
bimmerimies is offline   Reply With Quote
Old 05-10-2016, 10:21 AM   #82
bimmerimies
My Ride: BMW 330d
What if replace dual flywheel to single flywheel, is there clutch with springs available? If i undestand correctly with single mass flywheel need use different clutch... Quick search not found any brands
Old 05-22-2016, 02:28 PM   #83
bimmerimies
My Ride: BMW 330d
Ordering E60 clutch and CCC Motorsport single flywheel.
Old 06-12-2016, 10:44 PM   #84
bimmerimies
My Ride: BMW 330d
Do you use SAC or normal clutch with single flywheel?
Old 06-13-2016, 01:47 AM   #85
Sergio92
My Ride: 330CD E46 & 530D E60
I recomended OEM flywheel 330cd and clutch 530d 218ps eu3.
My vibrations with 600Nm of torque are produced because I dont change my flywheel.
I will change by a new flywheel oem for 330d e46.
Sergio92 is offline   Reply With Quote
Old 06-13-2016, 04:33 AM   #86
bimmerimies
My Ride: BMW 330d
You mean dualflywheel? Why? If gonna remap car like i do, only choice is single flywheel. And that flywheel what i ordering, is wrong(for 5- speed car). Not fit to my 6-speed car. Seller info was wrong. Now try to return and looking correct ones. Any recommending?
Did you use clutch plate with spring or w/o? ....if there is vibration.
If buy OEM flywheel, are all same what found in markets, is any better than others maybe?
Can use with OEM flywheel normal (not SAC) clutch? Some says SAC can take less power than normal clutch....
.....Or can use that E60 clutch with OEM flywheel too?
Old 06-13-2016, 09:53 AM   #87
bimmerimies
My Ride: BMW 330d
Originally Posted by CTID1987 View Post
E90 Clutch and Flywheel will NOT work with E46 6 speed.
E60 218ps clutch - (LUK part number - 624 3345 00)
E46 standard flywheel - (LUK part number - 415 0359 10)
How much this take torque? How to feel driving, vibations and how clutch feel in foot....?
Is E60 clutch SAC or normal?
And is e46 stock clutch SAC?
Old 06-14-2016, 04:51 AM   #88
bimmerimies
My Ride: BMW 330d
Where to buy that "E60 218ps clutch - (LUK part number - 624 3345 00)" ? It must be normal clutch (no SAC) and friction plate w/o springs. What i searched, all plates are with springs and that is not good if use OEM flywheel( there are springs all ready)
EDIT: I look my OEM clutch and suprice, its SAC clutch. So maybe that E60 SAC clutch is ok then? Does that clutch any special tool for installing? Or just release plate lock after aligment?
Old 06-21-2016, 10:01 AM   #89
bimmerimies
My Ride: BMW 330d
Single flywheel from ccc motorisport was wrong, not fit to 6- speed E46. So try to returning. Was seller mistake, because part info was wrong.
Now ordered OEM flywheel(same seller gonna send it...), because this seller and other seller told, single flyweel is not good for Diesel cars. Can damage gearbox and motor(resonation,virbation,etc)
And also E60 SAC clutch ordered.
Old 10-10-2016, 04:46 PM   #90
B480ZPX
My Ride: Bmw e46 330 d
I have a BMW E46 204HP and i managed to change it and got to 352HP and 766NM.In Romania it is the strongest.Did you know one strongest in Europe?352 hp ,no methanol,no NOS.
B480ZPX is offline   Reply With Quote
Old 10-11-2016, 05:59 AM   #91
Sergio92
Explain how to do...
Bigturbo, injectors, intercooler, exhauts, etc.??
Old 10-11-2016, 06:15 AM   #92
B480ZPX
Turbo Upgrade,injectors 0445110219,Big Intercooler ,exhauts 76 mm,egr off
https://www.facebook.com/photo.php?f...type=3&theater
Old 01-15-2017, 03:46 PM   #93
sydow
My Ride: E46 330d 150kw
What about clutch? What you've done with flywheel? OEM or something else, also did you have some vibrations right know? Tell me everything, please. Planing to put more power to my m57n, but the flywheel (i quess its becouse of it) makes so much vibrations, and i only have remaped, no others mods in car yet.
sydow is offline   Reply With Quote
Old 01-18-2017, 01:01 PM   #94
bimmerimies
My Ride: BMW 330d
What bigger intercooler fit?
Who made remap, what company?
Old 05-11-2017, 11:58 AM   #95
B480ZPX
Sachs performans and has no vibrations.The pedal it,s little hard.Intercooler coustom it,s made by somebody froom here.
Old 05-11-2017, 12:10 PM   #96
B480ZPX
now I have 390 hp 780 nm(limited nm) and with nitrous 450 hp and 870 nm.https://www.facebook.com/costiniulian.matei
Old 05-17-2017, 12:42 PM   #97
zander271
My Ride: 6spd ZHP/5sp XI
Good lord, that's epic.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
