Do I understand correctly that it's basically an automatic blinker kill switch? Turn the blinker on, it works for 2-3 seconds and then automatically turns off?
If so, I've never heard of anything like that on an E46, but we already have a slightly different alternative. Instead of turning the blinker on, gently press the stalk down, the blinker will turn on and when you let go of the stalk, it'll turn off.
I think he's talking about the feature where you can just tap the stock and it will blink 3 times. rather than turning it on then having to turn it off. you just do it hard enough so the the signal lites up let it go and it does the rest
yeah if you slighty push down on the newer bmws, benz, audis, it blinks 3 times automatically for you ( i like 2 times max changing lanes on highway, so not for me ) and holding it down itll stay on until steering wheel releases it or the driver.
Another way in which the driver is becoming more out of touch with the driving experience.
The blinker should remain on for at least a few seconds before any lane change or turn is made, and during the duration of the transition until it's completed. That said, there's no way even 5 blinks would probably suffice. It frightens me that car manufacturers are now basically preaching poor driving habits in a world (or at least country) where I thought we had already hit rock bottom.
I know the X3 has this feature, and electronics wise, the X3 is the closest BMW to the E46 in the current lineup. If it's retrofitable to the old X3s, then maybe it can be retrofitted to the E46 too.
I'd like to give this topic a nice kick. Was wondering the same thing. Is the comfort blinker build-in to the stalk/switch itself? Or would this be build-in to the OBC of the car? Does anybody know this? Info is much appreciated!
This thread is over 4 years old....anyway bmwmen, if you're looking for the one-touch triple blink feature all you need is an LCM module with s/w version 4.0 or 4.5. Then you can use PA Soft to recode the LCM module with your vehicle's VIN and change the mileage to 0000 so the LCM get's the mileage from your vehicle. Once you have this you won't have to worry about the dreaded tamper dot. Then you can use NCSExpert to code in the one touch triple blink to your new LCM module. That's it.
It's a pitty i just retrofitted auto head-light feature not so long ago and replaced LCM for that with a second-hand one. This one however has SW 3.01 on it. Do you know if it is possible to upgrade the software on the LCM maybe?
I'm looking at doing this sometime this year for my ZHP, probably during the summer. If you wouldn't mind sharing how you did this retrofit I would appreciate it! :thumbsup:
So far, no one has found a way to upgrade the software in your LSZ. I'm fairly sure that is just PROM and not EEPROM. Either that or just no software exists to properly update it.
you can't just update the s/w in your current LSZ. You have to purchase a new LSZ with either s/w 4.0 or 4.5. Either by finding one on eBay or going to the dealer for one. eBay being the cheaper alternative. That's what I did. Then all you have to do is code your LSZ to your car and use NCSExpert to activate the triple blink.
So now this makes me very very curious...does the actual 4.0 or 4.5 LCM software file exist somewhere? If so, I would love to join someone in trying to figure it out. Finding the actual chip in which the software is stored on and determining if it's rewriteable could prove to be extremely useful. It has to be flashed at the factory somehow. If we can figure out the chip and the actual pins that are associated with that flash, we could figure out how to tap into it and force the flash.
Heck, someone could make quite the business doing it $50 per flash? I'd do it. In fact, I know of some people who would be very interested in this project. I'll talk to them.
The processor on the LSZ (motorla/freescale MC9S12D256) has something like 2mbit built in flash memory. The EEPROM that PASoft dumps seems to just be a small section (kind of like dumping the data section of a DME). I have not come across anything that can write to the outside area, but the processor itself is programmable. According to the datasheet the writes can be disabled, but it didn't seem like it'd be too difficult to reenable.
I do believe that with the right tools, we should be able to update the software. The CI32-CI37 LSZss all seem to use identical microncontrollers. Some power circuitry seems to vary ever so slightly, but I don't think it'd inhibit functionality.
I came across your post in that thread documenting all of that. Very excellent information.
My friend and I are currently using it to see if we can come up with a solution to write to the flash memory We've got all the tools, just gotta figure it out. Everything is hackable! May need a chip burner initially, but we're trying to determine a way to do it without. Can you PM me the data sheet on the microprocessors?
All this talk of computers reminds me of my MKIV Jetta. Occasionally the wipers would just stop or the sunroof wouldn't move, and the only way to get them going again was to take the key out and restart the car.
I always used to use the, "3 blink and here I come" method of lane changes. I was stopped and chewed out by a State Trooper (no ticket) for doing just that. His words were, "This is not California, and we don't do lane changes like that". This was on a fairly empty stretch of Interstate, and I was well past the vehicle that I had overtaken. No reason for being stopped other than that. If you try it, be prepared to speak to the cop.
The company car I have (2012 Ford Fiesta) has the 3-times blink feature, if someone can call it a feature anyway. 3 times blink to show the other drivers that you are about to change lanes for example, is not simply not adequate. Everytime I tried it, I find myself trying to "abide" to the 3-times-blink by switching lanes faster obviously becoming less careful.
Actually I think it'd be pretty trivial to make it blink 4 or 5 times with NCS Dummy's ability to modify the daten files. I never tried since I found 3 to be adequate.
Looks like it may support a maximum of 7
Code:
CYCL_TI_BLK 00000501 (01) 07 ONE-TOUCH TURN SIGNAL FUNCTION
einmal 00 00 once E46
dreimal 03 03 triple
It really would be VERY easy, if this guy (Lucas) still made these things: http://www.jalt.de/?q=komfortblinker
It was very cheap, much cheaper than used LCM, at around $40 I think, and it was small enough, fully customizable, and it needed, I think, splicing a wire (or maybe two) going into LCM. When this thread came up again, I contacted the guy, and a few minutes ago I got a response from him that he doesnt produce modules at the moment but might start a new batch in a few months time.
As I recall, in NJ it is the law to signal before changing lanes and a few seconds after the lane change is effected. 3 blinks only makes you an accident waiting to happen...I'm sorry.
Also, my first reaction to this from the OP (years ago) was that you don't want to go messing around with our electronics too much.
Finally, since I like Charlie (cak), I have to reiterate...every which way I look at it...it's not a good idea. Also, btw, if you signal long before a lane change and long after it too...the troopers will think you're an old, careful driver, even when you're speeding! It creates an illusion of carefulness. :shhhh:
Terra, I trust, but I trust a good old 'on/off' turn signal better.
All of you in this thread now...perform the standard cleansing ritual for even thinking such things and read Bentley 120/13-16 four times.
I dunno. Virtually every new car has a 3-blink feature -- you'd think at least one of them would have had a longer period if there's no use for 3-blinks.
That said, even if configured to blink 3x, there's nothing preventing you from holding it in just as you did before. It'll continue to blink 4,5,6,etc... times until you let go. Or sometimes what I do is just tap it again after the 3 blinks for a total of 6.
Related Threads
E46 Fanatics Forum
17.9M posts
592.8K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
