Before anyone throws up the :search: smiley, I've already done it and no answer to my question on adjusting them.
search "adjust kw" (closest helpful answer)
search "adjust kw rear" (related)
Soo... I noticed that my front passenger side was higher about 1/4" than the front driver side. So I adjusted it to be about even with the front driver side height and all is good now. But I also wanted to adjust the rear passenger side because it was uneven with the rear driver side.
Like in the first search result post, when I try to adjust the height, the adjusting perch and base rotates when trying to use the adjusting wrench tool. nothing is holding the base in place. On the front adjusting perch, I had to use a allen wrench to "unlock" it so it would rotate, is there there something similar on the rear adjusting perch to "unlock" it?
