BMW e46 335ci N54 engine - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
The Showroom
Old 09-16-2015, 01:11 PM   #61
e46addictseba
My Ride: 2002 325ci
Any Updates?
RedCaliper Photography
insta- @redcaliperph
www.facebook.com/redcaliperphotography
e46addictseba is offline   Reply With Quote
Old 07-31-2016, 07:17 AM   #62
MAXixt
My Ride: e46 335ci
Just made brakes upgrade: CSL rotors all around ,csl protection plates and hand brake ,bmw performance calipers in front and porsche 996 in rear. Also we changed output shafts to 3.0D because oem 2.8 cant handle the torque,but it wasnt easy because I wanted to left oem small and light trailing arms from 328. Had a big problem because of the alpina wheels, because of the alpina design and offset its not enough place for big calipers, so we made spacers 9mm in rear and 21 in front and to keep the current wheel base we machined front king pins 6mm deeper on front pins ,rear are as they are only hubs are from 330 machined to smaller bearing and we made them 10mm longer to center the wheel.
MAXixt is offline   Reply With Quote
Old 07-31-2016, 07:24 AM   #63
MAXixt
My Ride: e46 335ci
Some pics of course
ID:	637709   Click image for larger version
ID:	637710   Click image for larger version
ID:	637711   Click image for larger version
ID:	637713   Click image for larger version
ID:	637714   Click image for larger version
ID:	637715   Click image for larger version
ID:	637717   Click image for larger version
ID:	637718   Click image for larger version
ID:	637719   Click image for larger version
ID:	637721   Click image for larger version
ID:	637722   Click image for larger version
ID:	637723   Click image for larger version
ID:	637725   Click image for larger version
ID:	637726   Click image for larger version
ID:	637727   Click image for larger version
ID:	637729   Click image for larger version
ID:	637730   Click image for larger version
ID:	637731   Click image for larger version
Old 07-31-2016, 07:27 AM   #64
MAXixt
My Ride: e46 335ci
By the way, first intercooler finaly was changed to wagner motorsport. My first one custom made now is running on highly modified 330d .
Old 08-02-2016, 11:26 AM   #65
MAXixt
My Ride: e46 335ci
new custom hoses
ID:	637839   Click image for larger version
Old 08-02-2016, 11:35 PM   #66
Mflara20
My Ride: 04 330i
Great build. Any recent pictures?
Sent from my SM-G925P using Tapatalk
Mflara20 is offline   Reply With Quote
Old 08-03-2016, 03:49 PM   #67
MAXixt
My Ride: e46 335ci
Will be a bit later, now left to change master brake cylinder to F10 with 27mm in front and 22 in rear.
Old 08-03-2016, 04:09 PM   #68
Mflara20
My Ride: 04 330i
So pretty much every part is interchangeable with a little modification between any bmw?
Old 08-03-2016, 07:57 PM   #69
rguti153
My Ride: 2004 zhp / 2000 323i
Beast
Sent from my SM-G935V using Tapatalk
rguti153 is online now   Reply With Quote
Old 08-04-2016, 03:26 PM   #70
MAXixt
My Ride: e46 335ci
I will make few pics to see difference , offset ,inner diameter and distance between studs are diffirent. But its not a problem at all, main idea is that only cilinder wich is plug and play is m3 but its almost the same as on 328 and for sure its not enough for my caliper set up.
Old 08-08-2016, 03:09 PM   #71
MAXixt
My Ride: e46 335ci
With the tank is oem 328 master cylinder , without is F10.
ID:	638229   Click image for larger version
ID:	638230   Click image for larger version
ID:	638231   Click image for larger version
Old 08-09-2016, 12:10 PM   #72
MAXixt
My Ride: e46 335ci
Already mounted.
ID:	638314   Click image for larger version
ID:	638315   Click image for larger version
Old 12-28-2016, 09:32 AM   #73
MAXixt
My Ride: e46 335ci
Finaly some performance parts arrived! Vargas GC-lite turbochargers, Spec super twin clutch set and Aem low pressure fuel pump for E85. Now still waiting for pcv valve from Vargas .
ID:	647916   Click image for larger version
ID:	647917   Click image for larger version
Old 02-11-2017, 03:13 PM   #74
MAXixt
My Ride: e46 335ci
Yesterday had a bit free time, so we installed the clutch and made 3 safety brackets for shaft. Im wery satisfied with SPEC production, perfect feeling on pedal, works without any noise and main- you can drive as with organic clutch withou any hits.
ID:	650120   Click image for larger version
ID:	650121   Click image for larger version
Old 03-29-2017, 03:33 AM   #75
YoitsTmac
My Ride: 328Ci
You rock man! Stock transmission doesn't complain? what'd you use for fuel delivery? What'd you do driveshaft wise?
YoitsTmac is offline   Reply With Quote
Old 06-25-2017, 04:20 PM   #76
MAXixt
My Ride: e46 335ci
Stock trans hold till 700hp , at the moment I have 495hp , now Im going to buy second HPFP set from Vargas and then we can make over 700hp. Stock fuel sistem with upgraded low pressure fuel pump and on E85 pulls only till 500hp , its dead end for it. Drive shaft is from 320d with 6 speed manual.
Old 06-25-2017, 04:31 PM   #77
MAXixt
My Ride: e46 335ci
On the 12 of june I took a part in one mile challenge in Estonia, for the first time results were rather good : 1km -248km/h, on 1 mile 280km/h , it was limit for my diff,so now I will put ratio 3:15 from e92 M3 dct .
ID:	657206   Click image for larger version
ID:	657207   Click image for larger version
ID:	657208   Click image for larger version
ID:	657210   Click image for larger version
Old 06-25-2017, 04:36 PM   #78
MAXixt
My Ride: e46 335ci
Some more pics
ID:	657212   Click image for larger version
ID:	657213   Click image for larger version
ID:	657214   Click image for larger version
ID:	657216   Click image for larger version
ID:	657217   Click image for larger version
Old 06-26-2017, 11:59 AM   #79
Ojai330i
My Ride: 330i Slick Top & X5
Your car is Legit!
Really incredible build
173 mph
Ojai330i is offline   Reply With Quote
Old 06-26-2017, 12:02 PM   #80
YoitsTmac
My Ride: 328Ci
Thanks for the great info. Great build!
