My first BMW - 2000 BMW 330ci 5sp Automatic - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
The Showroom
Old 04-25-2017, 04:33 AM   #21
Steve in Oz
My Ride: 2000 323Ci
Fern green really comes up beautifully in bright sunlight.
Steve in Oz is offline   Reply With Quote
Old 04-25-2017, 06:07 AM   #22
damills
Modded ///Member
My Ride: 2002 m3 & 2014 650i
2000 3-series coupe
In the USA the 2000 models were either a 323ci or 328ci. A previous owner changed the rear badge to appear as a 330ci.
Do this to be certain, get the last 7 characters of your vin and go to
http://bmwvin.com
I am not saying you are wrong, just check out the above URL or Hyperllink
I am so glad your happy, fun car to drive at any speed or badging if it is not an ///M3
Later
damills
damills is offline   Reply With Quote
Old 04-25-2017, 06:17 AM   #23
fordy_4
My Ride: 2000 BMW 330ci
http://bmwvin.com
Later
Thanks for the info damills, but already checked the VIN and it's a 330ci. Cross checked it with Auto Classic BMW (closest authorised BMW dealer) and it's a 330.
Australia got the 330i/Ci from mid 2000 onwards
My first BMW ---
2000 BMW E46 330ci
Fern Green Division
Question about belts & pulleys?
https://www.fcpeuro.com/blog/posts/m...elts-explained
fordy_4 is offline   Reply With Quote
Old 04-25-2017, 06:39 AM   #24
damills
Modded ///Member
Response
I stand corrected.
I would like to count my lack of accuracy to old-timers factly diagnosed with alzheimers, I am now 61.
Later dude
P.S.
Love your car, the 330ci had more HP and tourqe than the 323ci/328ci. I love the E46 so I got one the first at my dealership. Since 3 E36 3-series models, my count is at 21 BMW's now
damills
Old 04-25-2017, 06:59 AM   #25
fordy_4
Thanks Steve!
My first BMW ---
2000 BMW E46 330ci
Fern Green Division
Old 04-25-2017, 07:39 AM   #26
Steve in Oz
My Ride: 2000 323Ci
And yes Damills the E46 330Ci (as well as the 323Ci, 325Ci and 328Ci) was sold in Australia, and it is much sought after today. Fordy_4 has a fine example of the model.
Old 04-29-2017, 04:09 AM   #27
Steve in Oz
My Ride: 2000 323Ci
Nice write-up in The West Australian today!
Old 04-29-2017, 05:30 AM   #28
fordy_4
Was wondering if anyone on here would see haha
My first BMW ---
2000 BMW E46 330ci
Fern Green Division
Old 04-29-2017, 08:17 AM   #29
Steve in Oz
My Ride: 2000 323Ci
I would also suggest joining the BMW Club of WA. Good bunch of people, and you can do as few or as many of the club activities as you wish.
Old 05-29-2017, 08:56 AM   #30
fordy_4
Got the car back today from the panel beaters to remove the door dings and scratches from the last 17 years of use. Overall, very happy with how the car turned out. It's not washed or polished, and the photos are taken on my phone in the apartment garage so not the best setting I know
IMG_7367 by Christian Ford, on Flickr
IMG_7371 by Christian Ford, on Flickr
IMG_7372 by Christian Ford, on Flickr
I've ordered a wifi enabled ELM327 OBD2 reader to connect to my iPhone to hopefully diagnose the intermitted rough idle I'm having during cold starts. Research on here suggests either coil packs, spark plugs or vacuum leaks. Regardless, hopefully another simple fix I can do. On bigger things, the car will be going in for a Mango-approved full cooling system overhaul in October/November in preparation for Australia's harsh summer. This will entail a new radiator, new upper & lower radiator hoses, expansion tank, thermostat, water pump, pulleys and drive belt. I'll also endeavour to source a new windscreen cowl for a RHD E46 as mine is peeling due to the "Aussie" sun.
Mango-approved cooling system replacement link: http://forum.e46fanatics.com/showthread.php?t=914109
My first BMW ---
2000 BMW E46 330ci
Fern Green Division
Old 05-29-2017, 11:04 PM   #31
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
Wow, very clean
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 06-05-2017, 07:59 AM   #32
fordy_4
Had a long weekend today, so I decided to get started on diagnosing the oil leak. Searching and common thoughts are valve cover gasket (VCG) but upon closer inspection there is very very minimal oil on the exhaust manifold, and there's no burnt oil smell while driving or smoke. So, I've found it leaking from the front of the engine. First thought, head gasket leak
IMG_7396 by Christian Ford, on Flickr
To get a closer look, I remove the belly pan. Noticed it was severly damaged, from a kurb or rock I suspect, so I'll be ordering a new one soon. I took a can of degreaser and got to work cleaning all the oil off the belly pan, then started on the car. Wow, oil leaking onto the sway bar and what looked like the bottom of the starter or alternator. Cleaned that up too.
Before:
IMG_7398 by Christian Ford, on Flickr
As it's all clean now, I'll leave it as is for a fortnight, then check again to see how oily the pan is. That will tell me how serious the leak is. However, checking the dipstick leads me to believe it's not serious much at all, very minimal oil used since last change/flush.
Open to suggestions on where the leak's coming from? VCG is original, but as mentioned no visible leaks onto exhaust manifold
My first BMW ---
2000 BMW E46 330ci
Fern Green Division
Old 06-05-2017, 09:06 AM   #33
Steve in Oz
My Ride: 2000 323Ci
Just looking at the receipts from when I had some oil leaks repaired when I first got my 323Ci last year: camshaft cover gasket and oil filter housing gasket. I've had a spotless garage floor since!
Old 06-17-2017, 12:09 AM   #34
fordy_4
Another FCP Euro order today. Ordered a new belly pan & charcoal cabin air filter
Belly pan P/N : 51718268344
IMG_7490
This is a comparison between the old and new cabin filter
IMG_7492 by [url=https://www.flickr.com/photos/95313153@N02/]
My first BMW ---
2000 BMW E46 330ci
Fern Green Division
Old 06-17-2017, 12:20 AM   #35
tks
My Ride: slower than yours
love the color, beautiful car.
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 06-17-2017, 12:23 AM   #36
fordy_4
Thank you! With only 118,500kms on the clock it's been garaged a lot. I plan on doing another full detail before Summer comes again here in Australia which will really make the Fern Green come out again. The weather is to un-predictable at the moment
My first BMW ---
2000 BMW E46 330ci
Fern Green Division
Old 06-18-2017, 03:15 PM   #37
jaymtz80
My Ride: 330i 5spd+05 ZHP
Fern green FTW.....
2001 FERN GREEN 330I 5 SPEED SPORT PROJECT IN THE WORKS
jaymtz80 is offline   Reply With Quote
Old 06-21-2017, 04:20 PM   #38
Gunther325
My Ride: '04 325ci
Nice maintenance thread! Love your car. Are your windows tinted? If so, its a nice percentage. Keep up the good work.
Gunther325 is offline   Reply With Quote
Old 06-21-2017, 05:33 PM   #39
fordy_4
Thanks! I'm a firm believer in preventative maintenance when it comes to cars. I have a receipt from when they were done in 2011, but they are a 40% tint all around (I think!) I would personally like the rear windows darker, at 20%
My first BMW ---
2000 BMW E46 330ci
Fern Green Division
Old 06-21-2017, 06:07 PM   #40
Razz617
My Ride: 2004 330Ci
Nice thread! I have been having a coolant leak for a few months now, nothing big, but enough to bother me! Anyway, after close inspection, I found where the leak was. Actually, it was from the bottom of the e-tank. The hose wasn't all the way inserted & had a s-l-o-w leak. Just did it today. Pretty sure the problem is fixed!
Sent from my SM-N910V using E46Fanatics mobile app
Razz617 is offline   Reply With Quote
