M3 Differential Swap on Steptronic 325i [PICS] - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
The Showroom
Old 05-03-2010, 02:17 PM   #21
Mike@F1 AutohaŘs
Past Site Sponsor
My Ride: E46 330ci
Badass setup you have there
Mike@F1 AutohaŘs is offline   Reply With Quote
Old 05-03-2010, 03:17 PM   #22
WALKD U
My Ride: Just Fast!
It's a lot easier for a 330 than a 325. The axle shafts are thinner on the 325, which means the M3 ones won't fit 325 trailing arms. You can't bolt the 325 shafts to the M3 diff either because the M3 flanges have a larger diameter. I believe the 330 trailing arms will accommodate the M3 axles fine so you would only need the parts you listed (and miscellaneous things like the push rod). 330s also have a 6-bolt differential flange so you just use your OEM drive shaft. On the plus side, I did get a brake upgrade out of it.
Thanks!
Thanks for the input. You said Push Rod? Other thing, I will need is the M3 Rear Sway Bar.
-TrippinBimmer
FYI: Mine is an AUTO as well FTW!
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 05-03-2010, 06:47 PM   #23
n2Bimmer
My Ride: Loves Corners
Thats awesome man, Id love to do this, To bad im saving my $$
Old 05-03-2010, 06:48 PM   #24
cyberkaa
My Ride: E46 332i,M3;E30 325i
Originally Posted by Drewdown View Post
This has to be like the only time ive ever seen a Kalim multi-quote
Lies.
Thanks!
-TrippinBimmer
Yes, push rod (#12)
http://www.realoem.com/bmw/showparts...76&hg=33&fg=30
Good luck, man!
Thanks.
-Kalim
(klx photo studio)
Old 05-03-2010, 08:12 PM   #25
bigdog2003_99
My Ride: 2009 Audi B8
congrats man welcome to the lsd club the non drug oriented one lol
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
http://videos.streetfire.net/video/J...yan_186423.htm
bigdog2003_99 is offline   Reply With Quote
Old 05-04-2010, 01:37 AM   #26
rider-.
My Ride: 320i
isnt it possible to just change the flanges on the diff? im curious because i am doing this swap in my 320i.. (which im soon putting an m54b30 in) but i got the m3 subframe diff and 330 trailing arms and control arms. but i was wondering if i could just change the input flange on the diff so my driveshaft wouldnt have to be modified
rider-. is offline   Reply With Quote
Old 05-04-2010, 01:40 AM   #27
cyberkaa
That was my first suggestion when we got stuck on that part. We tried swapping the input flange but the non-M one didn't fit.
If you're using a manual transmission for your swap, the 330 drive shaft supposedly fits. I haven't verified this myself.
-Kalim
(klx photo studio)
Old 05-04-2010, 10:25 AM   #28
rider-.
My Ride: 320i
is that a 5 speed 330 drive shaft that will fit?
Old 05-04-2010, 11:47 AM   #29
cyberkaa
Yeas, that's the one I'm referring to.
-Kalim
(klx photo studio)
Old 05-04-2010, 12:47 PM   #30
Mc 007
My Ride: 325ci Performance
super
Mc 007 is offline   Reply With Quote
Old 05-04-2010, 11:22 PM   #31
rider-.
My Ride: 320i
can this be confirmed by anyone?
Old 05-05-2010, 07:58 AM   #32
JB_ZHP
My Ride: 05' ZHP Dinan 3
NICE...Would like to do this one day!!
e46 signature
JB_ZHP is offline   Reply With Quote
Old 05-05-2010, 11:18 PM   #33
cyberkaa
I found an old thread I used as a reference.
http://forum.e46fanatics.com/showthread.php?t=613741
According to that, you need the M3 drive shaft.
-Kalim
(klx photo studio)
Old 08-17-2010, 03:36 AM   #34
richyboycaldo
My Ride: Mx5 300zx 240z 330c
So which of there parts you listed are REQUIRED to do the swap on a 330ci steptronic? I assume that everything that has to do with brake is optional right?
The M3 parts I had installed include:
-Trailing arms $$ 60
-Dust shields diff cover??
-Axles
-Calipers
-Caliper carriers
-Rotors
-Brake pads
-Brake pad wear sensor
-Subframe $$170
-Differential $$ 650
-E-brake
-Wheel bearings/hubs
-Rear sway bar $$ 60
-Drive shaft (modified for length and balanced) if from m3 $250 (plus the modding)
-U-brace a.k.a. push rod $$ 86 new + core
-A bunch of bushings
richyboycaldo is offline   Reply With Quote
Old 08-17-2010, 07:45 AM   #35
cyberkaa
-Axles
-Calipers
-Caliper carriers
-Rotors
-Brake pads
-Subframe $$170
-E-brake
The brakes are optional only if you reuse your 330 trailing arms. Upgrading to the M3 arms means getting M3 brakes unless you have custom caliper carriers made to fit the 330 brakes. That wouldn't be cost effective anyway.
So the question is, can you reuse your steptronic 330 trailing arms? Based on the what realoem says about the size of the wheel bearing, probably yes. It depends on whether or not the splines on the M3 output shafts match up to the 330 drive flange hubs. Here's a comparison:
http://www.realoem.com/bmw/showparts...38&hg=33&fg=40 (325)
http://www.realoem.com/bmw/showparts...38&hg=33&fg=40 (330)
http://www.realoem.com/bmw/showparts...38&hg=33&fg=40 (M3)
The 325 bearings are definitely smaller, but the M3 and 330 ones share common parts. The drive flange hubs are different part numbers, though, so I'm not 100% sure if the splines match up. However, since everything else is common, you can probably install M3 flange hubs on your 330 arms in the worst case. They're not fun to remove and replace, so maybe an upgrade to M3 trailing arms and brakes becomes attractive again at that point.
I mentioned M3 output shafts above because you would need output shafts that fit the 94mm output flange on the M3 diff. Realoem shows 86mm and 94mm axles, and I think the automatics unfortunately got the 86mm ones. You'd have to measure to confirm and get bigger axles if that's the case. If you can find the 94mm 330 axles (I'm guessing from a car with manual trans or zhp), then you don't even need to worry about the splines matching the drive flange hubs.
So the remaining parts that you need are:
-differential
-subframe
-rear sway bar
-modified driveshaft
-U-brace
-Kalim
(klx photo studio)
Old 08-17-2010, 02:09 PM   #36
So Lowww
My Ride: E36M
hmmmmmmmm i wonder whats still missing from going into the car already damn it
S T A N C E | W O R K S
So Lowww is offline   Reply With Quote
Old 08-17-2010, 02:12 PM   #37
cyberkaa
I'm reading up on MSS54.
-Kalim
(klx photo studio)
Old 08-17-2010, 03:05 PM   #38
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
"reading up." Huh?
Drew@Swift Motorworks is offline   Reply With Quote
Old 08-17-2010, 03:31 PM   #39
cyberkaa
"reading up." Huh?
BMW training docs. I need to pick up a Bentley manual, too.
-Kalim
(klx photo studio)
Old 08-17-2010, 07:21 PM   #40
So Lowww
My Ride: E36M
lolwut?
