buying a used HPF M3 - Page 77 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.88 average.
Old 07-09-2017, 04:43 PM   #1521
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Originally Posted by cosmos328Ci View Post
Hi being3,
Did you use the ARP spec to clamp down the head for the cut ring head gasket?
Cheers.
P.S. looking forward to your beast being up and running.
Yes 105 feet lbs and was torque plated the same.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 07-10-2017, 07:50 AM   #1522
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
kool.
Thanks.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 07-10-2017, 08:39 PM   #1523
being3
Modded ///Member
being3's Avatar
Engine ruining going through heat cycle before re torquing head
Old 07-10-2017, 08:44 PM   #1524
being3
Modded ///Member
being3's Avatar
HPF AEM V1 running with Bosch 4.9 O2 sensor, noise suppression filter , ID1000 injectors , jumper box and DME modifications. Running perfect idle.
Old 07-12-2017, 10:48 AM   #1525
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Why do you have a boost target at idle?
WG DC was 80%, which indicates it was cycling the the solenoid trying to hit a target.
I've normally seen the boost target to be zero until say 3k rpm and 120 kPa of load.....
I know...I'm a jerk.
Congrats on getting the new engine running. Looks great!
Old 07-12-2017, 11:43 AM   #1526
being3
Modded ///Member
being3's Avatar
Good eye ... I don't even have the wastegate plumbed yet ... I'll make the adjustments during tune
Old Yesterday, 04:19 PM   #1527
being3
Modded ///Member
being3's Avatar
All buttoned up test driving complete... no leaks.
Old Yesterday, 04:36 PM   #1528
dtmpowerjc
My Ride: 2002 m3 silvergray
Sick
Sent from my iPhone using Tapatalk Pro
dtmpowerjc is offline   Reply With Quote
e46 m3, hpf, stage 2.5, turbo
Rate This Thread
