Cylinder Head Lift Under Boost?? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-07-2017, 07:39 PM   #1
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
After pulling down my engine that lost oil pressure which also used to pressurise the cooling system under boost, at the time it was around 20psi.
Inspecting the the engine block and cylinder head for combustion leak into coolant ports and the exterior of the MLS gasket there is no evidence, so instead of blowing the head gasket... I have head lift instead?... as when driving around below boost or maybe just a couple of pounds here and there there is no pressurisation in the cooling system.
With my spare engine in doing the work now with the schrick cams the boost dropped to about 17.2 - 17.4 psi but still pressurised the cooling system.
Therefore... more clamping force is required other than just a better or new head gasket.
Last night did some tests on OEM head bolts, ARP Ultra Lube (AUL) by its self and AUL with engine oil.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 07-08-2017, 04:58 AM   #2
Davconelectric
My Ride: 2 dog powered sled
Did you heat cycle the head gasket correctly?
Davconelectric is offline   Reply With Quote
Old 07-09-2017, 12:02 AM   #3
cosmos328Ci
It's one of my spare engines, already had about 120,000 km on it.
Sponsored Links
Advertisement
Old 07-09-2017, 09:30 PM   #4
Davconelectric
Oh. I thought you installed a New head gasket and cams.
Old 07-09-2017, 11:54 PM   #5
cosmos328Ci
No, no new head gasket yet.
I just put the cams in one of my spare engines and then put that spare engine in the car.
So I have a machine shop lined up to do a bore, hone, plateau hone, deck and machine head.
last part i need - Still looking for forged pistons before I will get the machine work done.
M11 time-sert the block and time-sert the head for cam trays.
Then I will slap it all back together with the cut-ring head gasket.
Then increase boost to 30psi.
Old 07-10-2017, 06:39 AM   #6
Davconelectric
With the ts? 30psi. Hmmm. You're not worried about melting it?
Old 07-10-2017, 07:46 AM   #7
cosmos328Ci
Yes, with the TS - 30psi is most likely not achievable without over spinning the TS more (I am already over spinning the TS). I would be happy with around 22psi, as at the moment I am around the 17.2 - 17.4 psi because of the cams - was at around 20psi before cams.
I hope to gain some more psi by increasing the throttle body (TB) size to to 4inch.
At the moment I have 3.5 inch TB mounted to the TS OEM size hole in the snout.
First: open the TS snout hole out to the 3.5 inch size of the TB - Dyno.
Second: adapt the TS snout to fit the 4 inch TB - Dyno.
After this I am really at the TS limits and will have to look at getting a bigger TS on the manifold. (I have done some measurements and looked at re-routing the by-pass valve, Etc, to fit the next size TS)
But, I really don't think I will go any further to have to use the next size TS.
Thanks for responding to the 30psi remark.
Old 07-10-2017, 04:12 PM   #8
Davconelectric
Exciting times ahead
Old 07-10-2017, 06:40 PM   #9
cosmos328Ci
LOL.
I have decided to buy some 10mm Raceware Head Studs to try and clamp down the existing engine head with the schrick cams so I can get it on the dyno to see how much difference the cams made.
Where did you get yours from?
Old 07-10-2017, 08:13 PM   #10
Davconelectric
LOL.
VAC I didn't bother shopping around. I ordered all my parts from them. Just easier
Old 07-11-2017, 01:47 AM   #11
cosmos328Ci
Thanks Davconelectric.
Old 07-12-2017, 09:39 PM   #12
cosmos328Ci
VAC Motorsports have not responded to any of my questions over the last couple of days. So, I have no idea what is going on with my order.
Achilles responded nearly straight away.
Oh well... Live and learn.
