ESS TS Pulley Upgrades - Page 12 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-28-2017, 01:34 PM   #221
Slopes330
My Ride: TiAg 330
I am as well, an email is already sent!
Slopes330 is offline   Reply With Quote
Old 06-28-2017, 02:20 PM   #222
rkneeshaw
My Ride: 330i ZHP
Originally Posted by Davew View Post
I am only questioning slopes330 as he stated he has the TS2+ kit and has an 85mm pulley, not 83mm or 81mm
Oh, right, I missed that, the 85mm is for the regular TS2, the TS2+ is supposed to have the 83mm (used to ship with the 81mm).
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Borla - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i ZHP
rkneeshaw is offline   Reply With Quote
Old 06-28-2017, 03:45 PM   #223
Slopes330
My Ride: TiAg 330
I know for a fact I hqve 85mm pulley, its stamped right on. I should've got the ts2+ kit, I've done a lot to this engine and its running strong, cool, and leak free (for Now) im going to hook up a boost gauge soon to see what boost I'm running. Just waiting to hear back from AJ. To much shady things going on, I'm not liking it. Any of you guys go and takr the tune further? Got more performance out of a custome dyno tune? Or was the map supplied optimal? I want to toy around with some more boost, and 75mm should peak at 12psi?
Sponsored Links
Advertisement
Old 06-28-2017, 04:24 PM   #224
Davew
My Ride: 2004 330ci Msport
I ran with a 78mm pulley for some time. Not too sure if you are going to need to change injectors to run a 75mm pulley though.
My last setup was with lower compression, 42lb injectors, and 65mm pulley on 98 octane.
The ESS file is ms430056, so there are xdf's for tuning.
If I had have stayed with the standard ESS setup and MS43, I would have converted to a HPX maf and further custom tuned.
Edit: Would also recommend you don't play with pulley swaps without a good Wideband and logging capabilities.
Davew is offline   Reply With Quote
Old 06-28-2017, 04:29 PM   #225
Slopes330
My Ride: TiAg 330
42lb injectors arent hard to come by. Green top bosch right? I dont, I'm lying, want to crack into the engine and start swapping internals just yet. I need to learn how to handle the car before I just start pulling boat loads of torque. I think thatll be a good place for me to start. 78mm, then I can swap to the 75mm and see how that works on a dyno. You're the man.
Old 06-30-2017, 08:00 PM   #226
Slopes330
My Ride: TiAg 330
Good news, ESS remedied the goof up and are sending out a pulley asap. They've been pretty good thus far. Hey davew, did you say you ran 78mm pulley on stock tune? Im going to shy away from trial and error for now until I get the car more finished. Random things like boost and afr need to be installed. I want to learn how to adjust launch control parameters and such first, tune the driver.
Old 06-30-2017, 09:36 PM   #227
Davew
I did run a 78mm pulley with the ESS TS2+ tune. ESS do not recommend this by the way. I went from what was at the time standard 81mm TS2+ pulley to 78mm.
Old 06-30-2017, 09:40 PM   #228
Slopes330
My Ride: TiAg 330
Did you see or notice any adaptation issues? This may be a good option to safely go from daily driver to track days as long as the fuel and trim is consistent. I dont know too many people with e46, unfortunately, but I would imagine these engines can handle a good amount of boost safely, the dme is sophisticated enough for the user to adjust parametets to pull even more. Alum block being the weak link.
Old 06-30-2017, 10:30 PM   #229
Davew
I did full logs and sent them also to ESS as a sanity check, all was good. This has a lot to do with how ESS set up their tune file. Their only advice was that if I did any more upgrades, I would need bigger injectors as I had them very close to their limit.
Old 07-03-2017, 07:40 PM   #230
jdjg
My Ride: e39, m52tub30
79mm pulley and stock tune here, no issue
jdjg is offline   Reply With Quote
