Lets build a MS43-turbo system! Specs etc... - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-07-2015, 11:05 AM   #61
daniel_f.
My Ride: 330iC
Thanks Dave,
i already got that sorted
Plenty of space as i forgot i donŽt even have gaskets between the head and the flanges. That should add another 2-3mm and i found a brave person which did some measurements for me.
So i will weld it tomorrow and having a bit of clean up.
ID:	586090   Click image for larger version
Old 01-07-2015, 06:03 PM   #62
Hobbit382
My Ride: 99-328i 00-323i
Originally Posted by daniel_f. View Post
Thanks Dave,
I'm kinda excited to see this happen, it seems like the n55 guys are getting a max of about 400whp and 470wtq. should be a fun little car.
Hobbit382 is offline   Reply With Quote
Old 01-08-2015, 12:49 AM   #63
daniel_f.
My Ride: 330iC
Hopefully
IŽm going to dive this into a E46 compact, which will be pretty light compared to my convertible. I hope it will be ~1250kg
Sponsored Links
Advertisement
Old 01-09-2015, 10:30 AM   #64
daniel_f.
My Ride: 330iC
Alright, finished the welding and took a look if the flanges are warped, no warp
IŽll start a little bit of porting this weekend
(edit) The intake ports definately need some proper welding to perform like i want Not the best designing nor casting
Old 01-10-2015, 11:11 AM   #65
daniel_f.
My Ride: 330iC
Just a little teaser
Old 01-10-2015, 02:53 PM   #66
zek926
My Ride: 325ti TS2+ / 320cd
Good stuff
Do you plan on using stock head gasket / bolts or have you got something else in mind?
zek926 is offline   Reply With Quote
Old 01-11-2015, 11:58 AM   #67
daniel_f.
My Ride: 330iC
IŽm not going high boost, nor high torque, for an easy test iŽll stick with the complete oem engine. Once the ecu is set up correctly and i have a baseline, iŽll probably change the head and maybe the gasket/bolts. WeŽll see
Old 01-11-2015, 07:17 PM   #68
mgunter
My Ride: E46 Touring & E30
I like the sounds of this! I can't wait!!!
You're my hero!
mgunter is offline   Reply With Quote
Old 01-14-2015, 06:57 AM   #69
GeorgeGG
My Ride: 323
manifold is matched very nice to flanges, i like idea, i would try it on some of my project cars to see how it performs for drifting. but unfortunately there is no N55 stuff available locally.
ive read that N55 Borg and evo 16g has same power level potential and they both perform same way so if its correct then u and Davew should see very nice spool and power figures at the end even on very low boost.
as for Injectors Davew told me that u were looking for injectors.
what i would suggest to go for is Siemens injectors from Volvo, they are very cheap on ebay and flow 43lb. also they perfectly match M52TU / M54 intake manifold and they are High resistance
Part number: 6900371
for 400hp power level u will not need to change fuel pump. stock is fine, i have used OEM pumps up to 390whp many times.
GeorgeGG is offline   Reply With Quote
Old 01-14-2015, 06:59 AM   #70
Davew
My Ride: 2004 330ci Msport
Thank you greatly George
Davew is offline   Reply With Quote
Old 01-14-2015, 06:59 AM   #71
daniel_f.
My Ride: 330iC
Thanks for clarification, thats what i found out to ordered two sets of 4 to have a little room to play.
IŽll PM you where to find such a turbo
Old 01-19-2015, 02:50 AM   #72
daniel_f.
My Ride: 330iC
Having a bit of AC welding fun in the next hours
Old 01-19-2015, 10:54 PM   #73
KendrickC
My Ride: '03 325i
Year: 2003
Model: 325i
Transmission: AT
I love you and davew's threads. So much information; so much learning!
Thanks for this, and good luck!
'03 325 Estoril Blue with some love from:
Turner, ECS, Remus, BMW Performance, G.A.S.,
Beisan, Umnitza, TRS, Radium Engineering,
Bilstein, AP Coilovers, Remsa, Whiteline,
Ground Control, APEX Wheels and more!
KendrickC is offline   Reply With Quote
Old 01-20-2015, 02:04 PM   #74
JL Fab
My Ride: 09 E92 335I
Evoiii 16g are good for ~350 or so and quick spool up on a 4cyl, for 400hp you'd probably want a 20g or bigger mitsu turbo. (I have a turbo ed mitsu motor with 16g in my mitsu pickup)
JL Fab is offline   Reply With Quote
Old 02-05-2015, 02:07 PM   #75
Clown Shoe
My Ride: E36/8
any updates?
Clown Shoe is offline   Reply With Quote
Old 02-05-2015, 02:11 PM   #76
daniel_f.
My Ride: 330iC
Currently not. The charger is finished, the first set of intake and exhaust ports are machined and now its waiting time to find a crashed car to throw that stuff into.
In the meantime iŽm working on the software, which isnŽt that attractive i think.
Old 06-02-2017, 03:05 AM   #77
dist01
My Ride: BMW 330I E46
any update?
dist01 is offline   Reply With Quote
Old 06-03-2017, 04:47 PM   #78
daniel_f.
My Ride: 330iC
Originally Posted by dist01 View Post
any update?
Not much, the modified N55 charger was placed to much to the front so i would have had to remove the ac compressor, which is an absolute no-go. I cut the manifold and also cut the input flange from the turbo. They came on different cars with a screw mounted, but i can't afford a new charger at the moment. So i designed some input flange Adapter to be welded onto the charger and connect them to some cut stock exhaust manifolds. So from top it will look like stock exhaust.
We are currently testing MAP sensor replacement, so i can remove the MAF. Idlespeedactuator is already removed and i put the blowoff valve in it's place. I have a set if high flow injectors waiting to be changed.
I also got a M56 valve cover, should help with ccv delete. I need a new ac condenser to match it with the 330d intercooler. Biggest hurdle will be the adapter from turbo outlet to under-car cats, thats giving me massive headache.
Old 06-03-2017, 05:34 PM   #79
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Hope it all goes well, will be nice to see you on the road after all this time and effort.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
