Thermostat Heater w/ Pics - Code P1619 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-29-2015, 01:11 PM   #1
captkhaos
My Ride: '02 330Ci
I thought I take some pics of the heater and thermostat out of the housing. The code was a P1619... MAP Thermostat Control Circuit Signal Low. I put in an old thermostat from a replacement (housing and all). The heater is fairly easy to remove as is the actual thermostat. Now I'd like to know if these components are available individually. The search begins.
BTW, has anyone had the housing fail?
http://s1.e46fanatics.com/forum/imag...attach/jpg.gif
ID:	618779   Click image for larger version
ID:	618780   Click image for larger version
ID:	618781   Click image for larger version
captkhaos is offline   Reply With Quote
Old 07-17-2017, 01:11 PM   #2
Husky390
My Ride: 2007 BMW 328xi
Replace the thermostat as a unit-critical
I had my thermostat malfunction. I left my home and noticed car was running funny within 2 miles of home. It did not respond to throttle inputs. I looked at my temp gauge on my 2000 323 coupe. All the way to hot. I shut it off and coasted to the side and waited. I had caught it early. No coolant loss. I let it cool down and limped car back to shop in 2 or 3 short drives letting it not get hot again. Next day, I took thermostat housing off the car. Thermostat had broken and that made it stick shut. Bad design!!!! It would have been good design to have it break and remain open. Luckily a year later car was fine. The reason I did not blow a head gasket was because I had not blown a hose and lost coolant. Driving a motor without coolant is an almost instantaneous blow head gasket-any car even a Honda. I found the complete unit at Smyth Auto Parts for under $50. Do not try to go the cheap way. Replace the entire housing compete with thermostat.
Husky390 is offline   Reply With Quote
Old 07-17-2017, 01:43 PM   #3
jmo69
My Ride: 03 325xi 98 328is
It's pretty hard to find individual thermostat parts for these cars, every supplier I've seen only has the whole unit. Behr or Wahler, one leaks around the heating unit, the other soft fails more often.
][/2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 07-17-2017, 03:13 PM   #4
Jason325xi
My Ride: 2004 325xi 5speed
Kind of off topic but yesterday I saw something funny Instagram. This lady went on a pretty long road trip because she was moving. Well the head gasket is blown o.k. her gas job obs f350. She went the whole trip using oil for coolant and apparently didn't overheat once lol
Adjustable koni yellow front struts, Rob43 9-way adjustable rear shocks, Special Rob43 lowering springs, supreme power drop hats, billet aluminum rear shock mounts, poly RTAB, G.A.S. Disa kit, G.A.S. 1.2bar expansion tank cap
I run 6010 overhead in a t-shirt!
Jason325xi is offline   Reply With Quote
Old 07-17-2017, 07:07 PM   #5
jmo69
Oil will absorb heat and if it won't cause a milkshake or mayo. Whatever works to get you through.
Old 07-17-2017, 07:29 PM   #6
Jason325xi
Yeah when I saw it I figured hey at least it'll just be oil mixing with oil instead of oil mixing with coolant lol
Disclaimer: I AM NOT ADVOCATING TO USE OIL AS COOLANT! Just saying
