Low oil after 3000 miles - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-28-2017, 05:28 PM   #1
QR
My Ride: 2005 BMW 325IX
Title says it all.
Back in April I bought a 2005, 325xi with 149,000 miles. I immediately did a complete oil change and after only 3000 miles (less then 2 months) my oil level is low. I checked the dip stick to confirm it wasn't a faulty indicator. What can I do to fix this? Would a thicker Oil help?
Any suggestions would be helpful
Thanks!
QR is offline   Reply With Quote
Old 06-28-2017, 05:33 PM   #2
My Ride: Lexus
Nope.
Assuming the engine isn't leaking a ton of oil, Engine needs to be rebuilt. Extremely common with BMW 6 cylinders.
Old 06-28-2017, 05:36 PM   #3
QR
Originally Posted by Mango View Post
Nope.
Oh god, what did I get myself into.. So I guess for the meantime I should continue to add more?
Old 06-28-2017, 05:40 PM   #4
My Ride: Lexus
Yep just add oil as needed. Cheaper than rebuilding the engine.
Likely the rings are just tired and oil burns up.
People like to say CCV CCV THIS THAT. 1% of the time it's the problem people are reporting: significant oil consumption.
It's reality these engines are old as poo.
And german cars in general burn oil. Brand new off the lot my 2006 E46 burned quite a bit. Drove it home with 5 miles on the odometer and I had to add oil regularly.
Old 06-28-2017, 05:47 PM   #5
QR
I appreciate the advice. I was just shocked that after less then 2 months I'd be out of oil. Should I continue with the Castrol Edge 5W30 or change it up?
Thanks again for helping me.
Old 06-28-2017, 06:14 PM   #6
My Ride: Lexus
I havent checked in the while but it may be the wrong oil. Castrol's Euro Oils are 0W-30, 5W-40, and 10W-40. Make sure it's Professional Euro that means ACEA spec. The #s mean next to nothing. Just make sure it's ACEA A3 B3 or whstever. Read up on it.
I would just use Mobil 1 0W-40 from walmart. The best in the business.
Old 06-28-2017, 06:15 PM   #7
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
How much did you have to add?
I check mine weekly and add half a quart now and then to top off. Price of admission for older cars, IMO.
Current: '02 330i/5 '10 Mazda5 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 06-28-2017, 06:25 PM   #8
QR
It looks like I'll need to add 6 or 7 quart's.
Old 06-28-2017, 06:37 PM   #9
Kpriest
My Ride: 2005 325i
The car holds 7 quarts when drained empty for an oil change. Just because the oil does not register on the dipstick does not indicate you need to add 6-7 quarts...
Kpriest is offline   Reply With Quote
Old 06-28-2017, 07:08 PM   #10
GhostFlame
My Ride: E46 Sedan
The difference between Full and Low on the dipstick, is about 1 quart.
Make sure you aren't leaking any oil from the Oil Filter Housing Gasket (OFHG - $5 part), or your Oil Pan Gasket.
If your CCV is working fine, and no mayo in the valve cover area / oil cap, no need to replace that.
Using even 1 quart of oil every 1000 miles is still completely within BMW spec, unfortunately.
You are doing much better than that.
I bet you are slow leaking at least half of your oil from the OFHG.
It sticks to the engine block as you're driving, combined with dirt, so you may never notice a leak on the ground from it.
GhostFlame is offline   Reply With Quote
Old 06-28-2017, 07:11 PM   #11
Pro325ie46
My Ride: 2004 BMW E46 325xi
Dont be so dramatic. Its normal with these cars. 3000 miles and being low is actually pretty damn good. I gotta add a quart every 1500 miles. Add a quart and youll be fine. Youre not COMPLETELY out of oil. Use ONLY Castrol 0w-40 or Mobil 1 0w-40 european formula oils.
Pro325ie46 is offline   Reply With Quote
Old 06-28-2017, 07:22 PM   #12
Silverdogz
My Ride: 2002 BMW 330Ci
When Mango is saying the engine needs to be rebuilt, that's only way to solve this problem. It's fine as long as it doesn't get worst, and you add oil.
Silverdogz is offline   Reply With Quote
Old 06-28-2017, 07:28 PM   #13
Jason325xi
My Ride: 2004 325xi 5speed
When I first got my car I would have to add half a quart about every 1500 miles. A coupe months ago I did the oil filter housing gasket, valve cover gasket and swapped the ccv for a m56 valve cover. I don't think the valve cover gasket was leaking but the oil filter housing gasket definitely was, there was pools of oil underneath it. I did an oil change when I replaced all the gaskets and I've driven almost 3000 miles since. I checked it yesterday and I haven't lost a drop.
You don't have to rebuild your engine, probably just replace a few gaskets.
Adjustable koni yellow front struts, Rob43 9-way adjustable rear shocks, Special Rob43 lowering springs, supreme power drop hats, billet aluminum rear shock mounts, poly RTAB, G.A.S. Disa kit, G.A.S. 1.2bar expansion tank cap
I run 6010 overhead in a t-shirt!
Jason325xi is online now   Reply With Quote
Old 06-28-2017, 08:26 PM   #14
TobyB
My Ride: 2004xit, 2001ci
a quart every 3k? That's fine. That's almost normal. That's certainly
better than many of us do.
Do read the (numerous, often locked) oil threads.
t
TobyB is offline   Reply With Quote
Old 06-28-2017, 08:31 PM   #15
jmo69
My Ride: 03 325xi 98 328is
Check your oil regularly and you'll know how much you're using. Oil weight and brand is you're choice, BMW LL01 is a spec that's acceptable. I've had good luck Mobil One and Castrol 0W-40 euro oils. My car apparently is a freak, no usage between 7500 changes.
][/2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 06-28-2017, 08:58 PM   #16
QR
Wow I'm a complete idiot. Sorry for wasting everyones time. Apparently I don't know how to read a dipstick correctly..
Old 06-28-2017, 09:02 PM   #17
Kpriest
My Ride: 2005 325i
Same here. Since resolving all leaks I haven't had any usage between 7,500 mile oil changes with M1. *knock on wood*
Old 06-28-2017, 09:07 PM   #18
Spannerhead
Save the Manuals!
Assuming you're not being sarcastic, at least you came here first before dumping 6-7 quarts into the engine..... No worries.
Old 06-28-2017, 09:11 PM   #19
QR
As sad as it sounds, I'm not. Definitely a low point in my life lol.
Added 1 quart tonight so I should be good. I'm definitely questioning if I added too much right when I got the car.. (Before I took it for an oil change)
Oh well, you live and you learn I guess.
Old 06-28-2017, 09:21 PM   #20
jmo69
You made it sound like you only checked the dipstick to double check the sensor. Sorry, I'm old school and check my oil at least once a week in my cars and daily on my work truck. My cars don't use any and my C-12 Cat with 262K has to go nearly 300 hours before it needs a gallon. IDK how low the level has to be before the sensor sets off the light.
Who did the oil change and did they put 7 qts in?
