Low end power problem - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-02-2017, 02:25 PM   #1
Starvega
My Ride: 323i
My 323 is down on power after replacing the head gasket. It runs and idles smooth a quiet but under 3000rpm it just doesn't have the power it used to, and it has a throaty intake sound. The are no stored codes and I've checked everything over many times and i just can't find anything wrong. The only hint i have is a pending p1520 code but it won't store it and it clears every time i shut the car off. I took the exhaust vanos solenoid off and cleaned it, the piston, and inside the vanos unit where it goes. I didn't see even a spec of dirt in there but i figured it was worth a try. No change. Cam position sensor is less than a year old, but the code is for the "actuator" anyway.
The only thing i can think of is maybe i messed up when i set the vanos upon reassembly? Would it be this noticeable if it was off by a little bit?
Starvega is offline   Reply With Quote
Old 07-02-2017, 02:48 PM   #2
armenh7
My Ride: 2002 325i
I think either DISA or vanos.
armenh7 is offline   Reply With Quote
Old 07-02-2017, 04:41 PM   #3
Starvega
My Ride: 323i
I rebuilt the vanos around January this year. The disa looked fine visually and doesn't make any noise. I haven't tested it though
Old 07-03-2017, 03:59 PM   #4
Starvega
My Ride: 323i
With the exhaust vanos solenoid unplugged, low end power seems to be back to normal. I didn't have time to drive it that much but it was good for the 10 minutes i did drive it. I'd rather have the cel on for a disconnected solenoid than have the power loss problem.
Still curious what would cause this? I might have to take the vanos back off and set the plungers again, i cant think of anything else it could be other than that i didn't set it right.
Old 07-03-2017, 05:31 PM   #5
Delineation
My Ride: JapanRot 05 325i
Bump
They said I could become anything, so I became a BMW owner.
Delineation is offline   Reply With Quote
Old 07-03-2017, 06:41 PM   #6
armenh7
My Ride: 2002 325i
Doesn't that sort of point to the vanos?
Old 07-03-2017, 10:22 PM   #7
Starvega
My Ride: 323i
Yes it points directly at the vanos obviously. But vanos what? Solenoid? Seals again? Timing problem? It's a fairly simple system, the whole thing doesn't just "go bad", but i dont know exactly what needs to be done to it.
Old 07-03-2017, 10:24 PM   #8
armenh7
My Ride: 2002 325i
Neither do I, sadly. We just have to wait for others now.
Old 07-15-2017, 08:59 AM   #9
Kalvis_325
My Ride: E46 325ci 330dA E90
Hi all,
not creating new thread - I have as I would say issue with my bmw power (e46 325ci manual). It runs fine (no check engine light, engine stalling, rpm fluctuation ect), but I feel that it has less power than it should have. I have measured 0-60 mph time with Torque app - 9.8 secods is the best time (while my e91 330dA had 7.6 doing without gas/brake start). 9.8 secods is way too slow for the car.
To illustrate see how it is going 80-120kmh (it is total sadness)...
40-140 kmh is the same sh...
I wear 224/40 and 255/35 R18 tires, 10w60 oil, all filters are changed, new spark plugs and there are no mechanical issues as far as I know. There is some noise in intake manifold, fuel pump is giving some noise.
What I should pay attention?
Kalvis_325 is offline   Reply With Quote
Old 07-15-2017, 08:28 PM   #10
domza2
My Ride: BMW e46 330ci
Noise from that intake?
Probably your disa valve. That can cause low end power problems.
They do go on these cars.
Rebuild the disa from a kit from G.A.S German auto solutions.
Just do a quick search on this.
Hope this helps.
Good luck
Sent from my E6653 using E46Fanatics mobile app
domza2 is offline   Reply With Quote
Old 07-15-2017, 08:29 PM   #11
domza2
Also 10w60 is not the right oil.
I'm just pointing this out.
To each their own.
Old 07-15-2017, 08:43 PM   #12
Starvega
My Ride: 323i
Mine pulls way harder than that video kalvis posted. Mine is just occasional low power at low rpm. Usually after idling for a while at a stop light or something. High revs are fine, pulls like normal.
Old 07-15-2017, 11:13 PM   #13
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
You could be off by one tooth on timing.
I did a head gasket once and had a cam position sensor error. New sensor did not fix it. I reworked the timing backwords to reset the timing and fixed the error.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptain
BMWCaptain is offline   Reply With Quote
Old 07-16-2017, 12:29 AM   #14
Starvega
My Ride: 323i
It's nearly impossible to set the timing chain wrong on these since it's just set to a general range. The vanos timing however, is really easy to set wrong. I'm pretty sure thats what happened. I don't have time to take it back apart right now though and i need to get ahold of the tool again. Its barely noticable with the solenoid unplugged. I can live with it for the time being.
Old 07-17-2017, 03:28 PM   #15
Kalvis_325
[/URL]
I had some track days, therefore such oil is used. for winter I will run 5w30.
Old 07-17-2017, 03:34 PM   #16
Kalvis_325
I have also thoughts on disa or vanos valve, since at the end it has almost no power... During test drive while purchasing it I felt some boost in power at the end (5000 rpm till 6000 rpm) and it was surprising for me, but it had some rattle/small jerking in the middle, and the seller solved problem in the middle and after that high end power was lost. I dont know what he did...
Also while pedaling there is some like vacuum.air going out noise (I think from disa). Is it normal?
