Help with CEL for O2 sensors (LOGS INCLUDED) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-03-2017, 01:34 PM   #1
Carlosss_
My Ride: 2004 325i
Hey guys, I have a 2004 BMW 325i with 94K Miles. It threw codes P2097, P2098, and P2270 so I replaced the intake rubber boots and cleared the code but to my surprise they returned.
All the codes that I'm getting are for post O2 sensors, Bank 1 says its signal is stuck lean but also that the fuel trim is too rich. How would this be ?
Bank 2 is just reporting fuel trim too lean.
I have ran diagnostics report on OBDFusion(which I will attach), but I just don't necessarily know what I'm looking for. I'm thinking I have a vacuum leak somewhere in the system and it's trying to compensate for it by throwing more fuel but then wouldn't my precat o2 sensors detect that and throw a code for the vacuum leak?
I'm attaching all the Logs and Diagnostic reports that would be required(read on jfoj pdf guide). If there's anymore info I can provide, please let me know.
Any help is appreciated!
Thank you!
(PRE_DIAGNOSTIC)-https://www.dropbox.com/s/az57ebp9nk...6-23.html?dl=0
(HIGWAY_RUN_CSVLOG)-https://www.dropbox.com/s/xe0rluq5wa...51218.csv?dl=0
(AFTER_HIGHWAY_RUN_DIAGNOSTIC)-https://www.dropbox.com/s/ckcsl5rsw6...6-23.html?dl=0
(4_MINUTE_IDLE)-https://www.dropbox.com/s/039v78dnzx...45052.csv?dl=0
(COLD_START_CSVLOG)-https://www.dropbox.com/s/m614hlh9vm...30705.csv?dl=0
(COLD_START_DIAGNOSTIC_REPORT)-https://www.dropbox.com/s/u5gwikh2mn...6-27.html?dl=0
Carlosss_ is offline   Reply With Quote
Old 07-04-2017, 08:14 AM   #2
markusmarkus
My Ride: 2001 330Ci
Are the sensors original? The pre-cat sensors need to be replaced every ~100k miles as they are considered maintenance items similar to brake pads. If they are original I'd change them first. Amazon has great prices on Bosch sensors. BUY ONLY BOSCH O2 SENSORS!
Make sure you label the O2 sensor harnesses as mixing them up will have you chasing your tail!!
Old 07-05-2017, 03:13 PM   #3
Carlosss_
My Ride: 2004 325i
Okay, I could probably get OEM ones. But why wouldn't it be throwing codes for the precat o2s? And what about the signal stuck lean code?
Regardless, I'll probably replace the precats just for maintenance now.
Old 07-10-2017, 03:42 PM   #4
Carlosss_
My Ride: 2004 325i
Anyone?
Old 07-12-2017, 04:54 PM   #5
Carlosss_
My Ride: 2004 325i
Bump
Old 07-12-2017, 05:21 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
Carlosss,
I will try to take a look at things a bit later this evening, I was out of the country for a week and recently returned and missed this post.
Old 07-12-2017, 06:11 PM   #7
jfoj
Quick look at the data, the MAF value is very low at idle, this is probably why the Fuel Trims are so high.
The question is the MAF bad or are the vacuum leaks causing the MAF to under report due to air bypassing the MAF?
Smoke testing will find the air leaks very quickly.
See this thread: Solve your misfires, lean codes, rough idle - http://forum.e46fanatics.com/showthread.php?t=897616
Old 07-16-2017, 07:39 PM   #8
Carlosss_
My Ride: 2004 325i
@jfoj I'd been busy this week and hadn't had time to check the thread again but thank you for reporting back to me! Would the vacuum leak have to be before the MAF or it could just be anywhere in the system and then the MAF still under report? If it's after the MAF then its probably my CCV since I have not changed it and I doubt the owner before me replaced it either.
Ill look and see who can smoke test it and see what comes out. The vacuum leak would still be responsible for the codes for the O2 sensors staying "stuck lean" though?
Old 07-16-2017, 08:40 PM   #9
jfoj
The low MAF reading could be due to a vacuum leak AFTER the MAF. Could be in the intake air path, CCV system or hoses, crankcase (cracked valve cover, leaking oil fill cap, dipstick O-rings flattened), Power Brake Booster, DISA O-ring.
So until you can rule out vacuum leaks, then this is the first step I would focus on. No since on replacing the MAF if the problem is due to vacuum leaks.
Vacuum leaks and/or a low MAF reading can cause the O2 sensors to be stuck reading a Lean condition that the DME cannot compensate for.
Old 07-17-2017, 11:50 AM   #10
Carlosss_
My Ride: 2004 325i
@jfoj Ah gotcha, I will be smoke testing it then and seeing where the leaks are!
