Front springs/shocks came off while lifting!!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 07-04-2017, 12:47 PM   #1
chazzz
My Ride: 2003 325i (my son's)
See picture... both sides (front only, left and right springs/shocks came out while lifting.).
NOTE: this isn't my car. It belongs to my teenager son. He didn't tell me about the noises while driving.
I need your advice and suggestions how to repair them. Thanks.
chazzz is offline   Reply With Quote
Old 07-04-2017, 12:48 PM   #2
chazzz
Forgot to add the picture.
Old 07-04-2017, 12:55 PM   #3
evanr614
My Ride: used 2 have 2 pedals
looks like you just need a new top strut mount? youll just need to pull the strut out and rent some spring compressors
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is offline   Reply With Quote
Old 07-04-2017, 01:36 PM   #4
All2kool
My Ride: 2002 325Ci
And here I thought I had seen everything.
All2kool is offline   Reply With Quote
Old 07-04-2017, 01:48 PM   #5
Silverdogz
My Ride: 2002 BMW 330Ci
That's amazing, you should post that on r/justrolledintotheshop. But it looks like the upper mount failed. Not a huge problem, just get a couple of lemfoerder upper strut mounts cause you should do both now.
Silverdogz is offline   Reply With Quote
Old 07-04-2017, 01:53 PM   #6
jmo69
My Ride: 03 325xi 98 328is
I don't see the holes in the old mount for the studs.
][/2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 07-04-2017, 02:26 PM   #7
cvx5832
My Ride: 325Ci, 325Cic, C300
I think you can ask whoever installed those struts. As pointed out it looks like it didn't have studs to begin with but the installer proceeded with the install anyway.
cvx5832 is offline   Reply With Quote
Old 07-04-2017, 02:37 PM   #8
chazzz
ok thanks for your suggestions. I removed the mount and the rubber part is worn-out and hard. I am going to replace them and the struts too...thanks!
Old 07-04-2017, 02:39 PM   #9
All2kool
My Ride: 2002 325Ci
Curious to see the top of the mounts in the engine bay.
Old 07-04-2017, 02:46 PM   #10
jmo69
I suspect mushroomed and ovaled out holes. I'd suggest these https://www.fcpeuro.com/products/bmw...46-51717036781 as a backup, cheap either way.
Old 07-04-2017, 11:58 PM   #11
Jason325xi
My Ride: 2004 325xi 5speed
Whoa lol it just fell out like that while jacking the car up? And like others said I don't see the studs on the mount. Post a pic of the top of the strut tower
Edit: just realized the mount isn't even there lol I'm assuming it's still attached to the strut tower I guess?
Adjustable koni yellow front struts, Rob43 9-way adjustable rear shocks, Special Rob43 lowering springs, supreme power drop hats, billet aluminum rear shock mounts, poly RTAB, G.A.S. Disa kit, G.A.S. 1.2bar expansion tank cap
I run 6010 overhead in a t-shirt!
Jason325xi is online now   Reply With Quote
Old 07-05-2017, 12:07 AM   #12
blksab65
My Ride: 323i/ 325i Touring
+1
blksab65 is offline   Reply With Quote
Old 07-05-2017, 12:56 AM   #13
jmtc
My Ride: 2003 325i Sedan
Yeah, it looks like the bearings completely separated from the mounts. I have never ever seen that before in over two decades of BMW ownership.
jmtc is offline   Reply With Quote
Old 07-05-2017, 08:03 AM   #14
ChuckyVee
My Ride: 2000 323i, '99 328is
Good lord...that crazy! Among other things, I'm really surprised that the tire is not showing some excessive/abnormal tire wear!
First Bimmer..."Miss December"...2000 323i, purchased Dec. 2013 w/82K on the clock. PM thus far...pads/rotors, belts/pulleys, complete CS overhaul, FCABs, plugs, autotranny/differential service, fuel pump, filter, and relay. Full front end refresh with LCAs and bushings, struts and mounts, inner/outer tie rods, sway bar endlinks and bushings.
ChuckyVee is offline   Reply With Quote
Old 07-05-2017, 11:44 AM   #15
Dave1027
My Ride: '06 IR zhp coupe
Yep. That's exactly what happened. Did this car have cheap aftermarket mounts?
Old 07-05-2017, 11:59 AM   #16
KlausH79
My Ride: 2001 325ti
That is an amazing sight....not in a good way ***128521; you've got to upload a picture of the strut tower in the engine bay....and also of the unmounted strut mount.....my curiosity is killing me....***128513;
Sent from my Nexus 5X using Tapatalk
KlausH79 is offline   Reply With Quote
Old 07-05-2017, 01:20 PM   #17
My Ride: Lexus
If that's like that, I'd hate to know the condition of the rest of the stuff. Your son was one big bump away from a disaster. You should get new struts/shocks and mounts all the way around. Get reinforcement plates while you're at it. Make sure your balljoints arent busted out and loose as well. Inspect all critical components and fasteners!
Old 07-05-2017, 02:32 PM   #18
Fox Fader
My Ride: '05 325i
Looks like the bearing came completely apart separating... leaving part of the strut mount attached to the shock.
'05 325i handshaker CW Package 130k
M Shift Knob - 545i Short Throw w/ Blk Suede Boot - Tint: 20%r, 35%f - PowerStops
HomeLink® - Clear Fender Signals - LED Interior Lights - Tein S.Tech - Koni Str.t - Clear Corners - Yellow Fogs
10 Ford GT 401a 5sp 17k miles
17 High-Ball Matte Nuclear Sunset Orange
11 KLR 650 (sold) :(
07 Tuono Factory
03 F150 STX Lightning replica
11 Kia Sorento SX (wife's)
Slammin Tunes
Fox Fader is offline   Reply With Quote
Old 07-05-2017, 04:17 PM   #19
chazzz
Yes, you're correct, the mount is still attached to the strut tower.
I just ordered many suspension-related parts for my son's BMW. I should get them by next week. I will take a picture of worn-out (or damaged) mounts and post it - at the same time I replace the parts. I'll post the picture next week.
Old 07-05-2017, 05:10 PM   #20
TobyB
My Ride: 2004xit, 2001ci
That's what I was thinking- but I've never seen one come completely apart before, either.
t
TobyB is offline   Reply With Quote
