Steering hard to turn - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 07-06-2017, 03:38 PM   #1
SiVaE46
My Ride: 2003 325i
I replaced all belts and pulleys on my 325i - noticed the ps pulley had some play - and am getting a lot of "rattle" from the front of engine when idle.
Screw driver test on pump showed a lot of noise coming from that area - so I replaced the pump with a Napa remanufactured one.
That also has a similar play on the pulley (I pulled a pump from a '99 in the junk yard and it had no play - but does not fit my '03).
Anyway rattle is still there - I think vanos now - but after I refilled pump reservoir and bled (turned lock to lock a few times with cap off) - I get a slight hum from pump when turning the wheel at parking speeds and sometimes the steering is very heavy at park speeds.
Fluid level with BMW ATF is good. Old fluid came out red - and looked fine. Put in redline d4 atf to
Above 10 mph steering is fine (and feels tighter than the old pump - in a good way)
Do I have a bad pump or should I check something else ?
SiVaE46 is offline   Reply With Quote
