2001 330ci rear end clunk / creak - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 07-15-2017, 04:41 PM   #1
JRK12
My Ride: 330ci
My car has a noise coming from the rear end. I can only hear it when driving in reverse, driving slowly in 1st and 2nd gear and while making tight turns. It doesn't happen when hitting bumps or pushing up and down on the car.
I thought it might be the rear shock mount, but it doesn't seem to be from the video that I took. The noise goes away when it's wet. It's also intermittent, it doesn't happen all the time.
I greased the rear sway bar mounts and checked everything in the rear. I can't figure out where the noise is coming from.
I'm thinking it might be the rear trailing arm bushing. Does anyone have any insight?
_a_
JRK12 is offline   Reply With Quote
Old 07-15-2017, 08:19 PM   #2
domza2
My Ride: BMW e46 330ci
My 330 was clunking from the rear.
Check the subframe for cracks.
I changed the diff bushes, that fixed the problem.
Then the noise came back, I checked the subframe bolts ( 4 bolts that connect the subframe to the car) the rear left bolt was loose. I tightened it up half a turn and that fixed the problem.
Good luck
Sent from my E6653 using E46Fanatics mobile app
domza2 is offline   Reply With Quote
Old 07-16-2017, 02:50 AM   #3
captkhaos
My Ride: '02 330Ci
U joints can creak when worn. Autos usually wear the fronts first, manuals wear the rear.
captkhaos is offline   Reply With Quote
Old 07-17-2017, 01:30 PM   #4
JRK12
My Ride: 330ci
Good luck
I definitely need to replace the diff bushings. One of them is very visibly cracked. I don't think it's the cause of this noise though.
I'll take a look at the subframe bolts and see if they are all tightened down. Maybe the subframe to the car bushings have worn slightly in the past 16 years, which cause a small movement and noise. If that is the case, I can see how tightening them would get rid of the noise.
I'm hoping where the subframe mounts is not cracked. I looked and could not see any cracks, but I know they can be hidden under the sheet metal in the trunk.
Old 07-19-2017, 06:14 PM   #5
ReeceEngM54
My Ride: E46 330ci
Let us know because Im having a similar issue. Ill be driving forward, come to a stop and park. When Im leaving my house in the morning and am backing down my hill Illl rest my foot on the brake and hear a pop/whack noise. Except mine sounds like it comes from the front end of the car.
However it makes no sense for the front end to be making this noise. Ive had new control arms put in and I replaced the lower control arm bushing as well. Not much left up front to replace. Ive also had 2 of the 3 rear diff bushings changed as well.
Im about ready to remove my subframe, get rid of any rust, repaint, replace all rear bushings and thrown in an LSD while Ive got it apart, then have my brother weld in the rear reinforcement plates. Not a bad idea but Id rather spend my time putting a new clutch and 6speed in my e36 to get that car back on the road.
ReeceEngM54 is offline   Reply With Quote
