Help passenger door latch will not release - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-17-2017, 05:17 PM   #1
chariotdrvr
My Ride: 2000 328ci
2000 BMW 328ci, Passenger door latch will not release to open door. Both inner and outer door handles will not work. I have the inner door panel off, and the two nuts holding the window frame in front of the actuator. Both handles appear to be functioning properly. I have worked them both and have a inspection camera on the actuator, all the linkages move when the inner and outer handles are worked. The black plunger lock/unlock rod is connected and it works also when the remote button is pressed, the linkage on the actuator moves. The black plunger,rod for the door lock works by remote. It does the double click unlock and the plunger pops up and it locks again when the remote button is pushed or by pushing on it manually, or when car is above 10mph. I have a new actuator on order, should be here in a couple of days. Cannot replace it til I get the door open. Can anyone help.
chariotdrvr is offline   Reply With Quote
Old 07-17-2017, 05:49 PM   #2
jmo69
My Ride: 03 325xi 98 328is
If moving the horizontal rod is connected and isn't doing anything, it sounds like the actuator is broken internally. Unfortunately it's held on from the end of the door. Maybe you can learn something thing from the new one, otherwise it sounds like you may have to try and break enough of the old one to get it out.
][/2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
