Old 03-07-2013, 11:09 AM   #1
austinadrew11
My Ride: 2001 BMW 330Ci
Window Problems
I have a strange poblem with my window. If I open my driver's side window while going down the highway, It will not close properly. It seals at the top, but bulges out towads the middle. I don't have this problem on the passenger speed. I also have a lot of wind roar at motorway speeds. Im thinking the roar started during last summer after I got my lock actuator replaced. Any ideas?
austinadrew11 is offline   Reply With Quote
Old 03-07-2013, 01:21 PM   #2
trj
My Ride: 325Ci
May be the window wasnt seated right when they did the door actuator.
I am pretty sure the window needs to come out for the door actuator repair replacement in a coupe.
When I did my door handle, I have to remove the window and then window guide on the actuator side.
Remove the window and reseat it. Also try to check if the door is aligned and seating flush to the B pillar base. Check goingnuts post for door alignment for DIY.
330ci, problem, strange, window
