Old 12-19-2013, 05:50 PM   #1
polishfc
My Ride: BMW 323ci
Exclamation Rim/Possible Spacers (hopefully not) Question.
Hi,
So i know this may seem cheap but I got a set of brand new rims and tires from a friend who had them laying around the past week, they look nice (not the ***** rims) not OEM but same size, bit larger tire 235 instead of the 225 I orignally have on my 323ci, but when i was trying to install them I ran into the problem of different bore sizes (rim: ~70mm car bore:~72mm) and well im in a bit of a dilema I want to install them but i have no idea on how to supposidly there arent any spacer which decrease the size of the bore (only increase) and if i use the flat spacers ill have vibration and potential suspension problems. I mean if it involves drilling ill look into it but not to fond of drilling through the rim. If anyone has idea maybe potential places where i can order some spacers or something would be greatly apreciated. If not i guess ill have a set of tires and rims to sell :p
Thanks in advance
polishfc is offline   Reply With Quote
Old 12-19-2013, 11:00 PM   #2
CSP
My Ride: m54
pcd adapter or bore the wheel.
CSP is offline   Reply With Quote
Old 12-19-2013, 11:25 PM   #3
WDE46
My Ride: '13 128i, '04 330Ci
Get correct wheels. Problem solved.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 12-19-2013, 11:25 PM   #4
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
You should get wheel adapters that go from the 5x120 BMW pattern to the 5x4.75 GM wheels you're putting on.
Cavi Mike is offline   Reply With Quote
Old 12-20-2013, 04:02 AM   #5
NumbaOneNewb
My Ride: 2003 330CI Silver
Those who have suggested adapters might mention they aren't cheap. Buying all 4 may put the cost of those over the top of what those rims are even worth
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
bore, hole, rims, small, wheel
