Old 01-22-2014, 08:22 AM   #1
dbasonic
My Ride: 02 330ci
Unhappy 2002 330ci- passenger window stuck down
I know a lot of times this is the regulator but I think this is something different.
Last night my girlfriend spilled juice by the cup holders that spilled also onto the window switches by the shifter. Immediately after both front and rear windows went the whole way down, and got stuck in that position.
I got into the car this morning for work in 15 degrees Fahrenheit, and tried the windows again. The rear side window came back in, but the front one still did not move. So with that being said, since the switch got wet in such cold temperatures could something of froze? Not sure what to do, this happened before and only needed awhile for the switch to dry off and then easily went up.
It's freezing cold and desperately need to get my window up.
dbasonic is offline   Reply With Quote
Old 01-22-2014, 09:14 AM   #2
paraklas
My Ride: ESS TS2 320ci
Take off the switches, open them, spray some contact cleaner let them dry and retry
Old 01-22-2014, 05:48 PM   #3
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
Disconnect the window switches and then use your key in the driver's door lock, turn to lock and hold. Hopefully your car is programmed to lock the door, close the windows and sunroof. Buy new switches or good used ones. I see them on eBay for not much money.
scottjoh is offline   Reply With Quote
Old 01-22-2014, 06:04 PM   #4
330ism
My Ride: 2004 330I ZHP
^^ what they said^^ and never ever let your girlfriend drink in your car again!
330ism is offline   Reply With Quote
Old 01-22-2014, 06:26 PM   #5
mjpgolf1
My Ride: 00 328i,05 745,03 X5
+1
Women can't do anything in a car without breaking or staining something. Hope you figure it out OP.
mjpgolf1 is offline   Reply With Quote
Old 01-22-2014, 06:30 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Originally Posted by mjpgolf1 View Post
+1
Old 01-22-2014, 06:32 PM   #7
mjpgolf1
Originally Posted by Solidjake View Post
Lol. I guess that could be interpreted a couple different ways.
Old 01-22-2014, 06:44 PM   #8
My Ride: Lexus
Doug has stained his interior before. With something red. I'm not allowed to say what.
damage, switch, window
