code p0335, crankshaft position changed still problem - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-01-2014, 09:17 PM   #1
nickrobert21
My Ride: bmw 325ci 2001
Angry code p0335, crankshaft position changed still problem
my car not ruining great rought idle, ruff start and code p0335. I changed that sensor and the check engine is still on. The idle is the most terible when A/C and/or defrost is on. Someone got this issu and solved it. Sorry for my english i speak french :p
nickrobert21 is offline   Reply With Quote
Old 12-01-2014, 09:46 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Do not worry, your English is better than my French.
What brand crank sensor did you use?
How much did it cost and where did you purchase it?
Can you read the warm idle Fuel Trim values and post this information?
Also can you post any Freeze Frame data?
Old 12-01-2014, 09:59 PM   #3
nickrobert21
I bought my sensor at a part shop i always buy my part there and i paid 50$ and you wanna know at which idle it stay normally ?
Old 12-01-2014, 10:00 PM   #4
nickrobert21
If is what you mean i will chek this for more precison tommorow morning.
Old 12-01-2014, 10:12 PM   #5
jfoj
The problem with non OEM sensors and these German cars they can often be problems. It is always best to use the OEM sensor manufacturer Siemens/VDO which I believe is the OEM supplier and I believe these would be a bit more than what you paid for your sensor.
Cannot say this is the exact problem why you are still getting the crank sensor error, but I would gather this may be part of the issue.
Old 12-02-2014, 07:40 AM   #6
markusmarkus
My Ride: 2001 330Ci
I helped a guy change the crank position sensor on his E39 with an M54 engine. It ran rough after the swap (yes, it was an oem sensor). He shut the engine off and I cleared the codes with my trusty Peake reader. The engine ran smoothly on restart. I guess the ECU thought since the cps error hadn't been cleared it would ignore the cps data.
OP, have the error cleared and then restart the engine. And yes, make sure you install an oem sensor.
Je ai aidé un gars changer le capteur de position de manivelle sur son E39 avec un moteur M54. Il a couru après la rugueuse swap (oui, ce était un capteur OEM). Il éteignez le moteur et je effacé les codes avec mon fidèle lecteur Peake. Le moteur a fonctionné sans heurts au redémarrage. Je suppose que l'ECU pensé puisque l'erreur cps ne avait pas été autorisé il serait ignorer les données cps.
OP, ont effacé l'erreur, puis redémarrer le moteur. Et oui, assurez-vous d'installer un capteur oem.
Old 12-02-2014, 08:45 AM   #7
nickrobert21
I would like to know if someone know if there aek other problem that can cause a p0335 code or if someone solved is problem by putting a oem crankshaft sensor. I reset my check engine yerterday again thant a droved this mornig to school same issu for de idle and check engine was off maybe he will pop when i will restart the car.
Old 12-02-2014, 09:22 AM   #8
lszlszx
My Ride: 1.8T, XC70
Non OEM sensors are known to be unreliable, so if the code comes back, your first step should be to install an OEM sensor.
Other causes for that code are improper installation of the sensor, wiring, or electrical issues. Those are not common though.
If the code won't come back, but the idle continues to be rough, there is another problem that needs trouble shooting.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 12-02-2014, 09:40 AM   #9
nickrobert21
Thank you for your help. Because a say post that were like mine but no one seems to have solved is problem :p
Old 01-14-2015, 08:49 AM   #10
Morello
My Ride: e46 330 ci
Did you sort it out?
Morello is offline   Reply With Quote
Old 01-14-2015, 08:58 AM   #11
nickrobert21
Yes it was just the crankshaft sensor that was not at is good place now everything is find
Old 01-14-2015, 09:09 AM   #12
Morello
My Ride: e46 330 ci
Did you do a parts level diagnose or did you just replace on chance?
Old 01-14-2015, 10:13 AM   #13
WDE46
My Ride: '13 128i, '04 330Ci
So you swapped for the OEM version or the sensor you put in was installed badly?
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 01-14-2015, 11:02 AM   #14
nickrobert21
The sensor i put was just install badly, i uninstall it and i saw that the o-ring was crush on one side.
Sorry for my english ahah
check engine, crankshaft sensor, idle, p0335, rough idle
