Coolant leak - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-12-2012, 07:42 AM   #1
Kealbazor1
My Ride: E46 318i
Exclamation Coolant leak
I have been leaking coolant ever since i first bought my car (2000 e46 318i) coolant is leaking onto floor directly under heater behind engine. Currently needing to fill up about a litre every 2-3 days. Had it checked today and mechanic said i need a new plastic pipe or something that runs from the front of engine to the back of engine. Have to dismantle everything to see properly but havent done so yet. Wanting to know the name of that part and price please. And other questions and info will be great.
Thanks, Anthony
Kealbazor1 is offline   Reply With Quote
Old 04-12-2012, 08:45 AM   #2
Akovski
My Ride: 323CI
check out OEMparts.com they have plenty of diagrams for u
Akovski is offline   Reply With Quote
Old 04-12-2012, 09:14 AM   #3
her01981
My Ride: 2005 325CI Convertib
Search ebay for BMW E46 Coolant Tank. It runs about $40
I had the same problem. I took it to my buddy, he took it out and sure enough there was a small crack on the side of it. Bought the part from ebay and he installed it. All good!
her01981 is offline   Reply With Quote
Old 04-12-2012, 09:49 AM   #4
Kealbazor1
My Ride: E46 318i
On the cooling system diagram here it shows it as being called heater inlet pipee? Thats the only one looks like my description.
http://www.realoem.com/bmw/showparts...15&hg=17&fg=05
Old 04-12-2012, 09:52 AM   #5
CaptainOversteer
My Ride: Has three pedals
Replace the whole cooling system. There's a great sticky on it, and it will save you headaches down the road.
Now Coding Cars in the Burlington,VT/Plattsburgh, NY area - PM if needed
BMWCCA # 461124
1986 325 - SOLD
2002 325ci - gone :(
CaptainOversteer is offline   Reply With Quote
Old 04-12-2012, 10:02 AM   #6
Kealbazor1
My Ride: E46 318i
How much would that cost? I don't have money as yet and am selling the car just tryna repair stuff first
Old 04-12-2012, 10:14 AM   #7
younGun392
My Ride: S.L.O.W
Most likely option is the expansion tank (coolant tank), probably just a simple hair line crack on the side of the tank which is only leaks when hot water runs through. Get a compression test maybe?
younGun392 is offline   Reply With Quote
Old 04-12-2012, 10:18 AM   #8
My Ride: Lexus
See sig. Do it. If not, light car on fire. thanks bro
Old 04-12-2012, 11:38 AM   #9
manaman22
My Ride: 2000 323i
Based on what you are saying, you are correct. Your mechanic is describing the heater inlet pipe (number 8 on your drawing). You should replace the other plastic pipe (number 6) while you are in there, since it is accessible. You just need to order the pipes. They usually come with the o-rings already on them, so that can save you a few bucks. For both pipes, you should look at about $75US. It is just a matter of where you get the parts from and the shipping cost.
manaman22 is offline   Reply With Quote
Old 11-04-2015, 10:50 AM   #10
invisible132
My Ride: E46
Hi! I can't find part nr.5. Can someone tell me how should I reach it? http://www.realoem.com/bmw/enUS/show...diagId=11_2082
invisible132 is offline   Reply With Quote
318i, coolant, e46, leaking, radiator
