2004 e46 / 325ci Cranks won't start replaced Fuel Filter Pump, Cram Crank P-Sensor - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-30-2016, 08:12 PM   #1
valleyland
My Ride: E46
2004 e46 / 325ci Cranks won't start replaced Fuel Filter Pump, Cram Crank Position Sensor, Oil Sensor.
I've been battling with my car for the last two weeks, I have replaced everything mention above and have check all of the fuses that are related to ignition switch, fuel pump and EWS but every fuse is ok.
HISTORY:
My car is an 04 with 126K+ miles So replacing all of the above mention items were necessary for the car to continue it's life. However the car still won't start. Just cranks The battery voltage is good, the starter works fine with enough voltage to start.
I'm just stuck now. If anyone can shed some light into this problem it would be greatly appreciated.
valleyland is offline   Reply With Quote
Old 04-30-2016, 08:33 PM   #2
white_335i
My Ride: 03 330i/M3/5/6 spd
Did you check spark at the ignition coils? Fuel pressure at the rail?
white_335i is offline   Reply With Quote
Old 04-30-2016, 08:34 PM   #3
valleyland
My Ride: E46
yeah, I also change the park plugs on the car, and the fuel pressure is good too
Old 04-30-2016, 08:39 PM   #4
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Tell us what your battery voltage is.
Did you check the fuses in the E-box?
Did you change the horn relay for the fuel pump relay?
Do you hear the fuel pump prime?
Did you try starting the car with the gas peddle all the way to the floor?
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptain
BMWCaptain is offline   Reply With Quote
Old 04-30-2016, 08:50 PM   #5
valleyland
My Ride: E46
The voltage is over 12v when start; the fuses are all good,
My car doesn't have a horn. Is one of those few cases where it wasn't factory installed. The previous owner (I'm 2nd owner) said that I could take to the BMW for them to install it with no charge, but I never did. So there's no horn relay that I'm aware off
I fuse does prime, the fuel has enough PSI pressure on it.
Old 04-30-2016, 08:52 PM   #6
valleyland
My Ride: E46
The *fuel pump does prime
Old 04-30-2016, 11:13 PM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
EVERY car produced has a horn, it is a basic safety and legal requirement. You must have a 1 off build if your car was not built with a horn.
Are you referring to an alarm siren? This is a very different story and part from the horn.
Do you have any extra keys you can try??
Have you tried a 2 second burst of starting fluid into the MAF to see how the engine responds?
Just because you hear the fuel pump prime does not mean you will have fuel/fuel pressure at the fuel rail.
How much fuel is in the tank? If the fuel pump is soft failing and you are around 1/4 of a tank, add a few gallons of fuel, cycle the key about 6 times to purge the fuel system of air and try to start the engine.
Old 05-01-2016, 07:59 AM   #8
markusmarkus
My Ride: 2001 330Ci
2004 e46 / 325ci Cranks won't start replaced Fuel Filter Pump, Cram Crank P-S...
Even if a pump provides adequate pressure it can fail to provide adequate volume of fuel.
Have you scanned the ECU for codes?
cranks, no start
