Rough Idle Fixed! Adjuster Unit Culprit - Page 8 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 177 votes, 5.00 average. Display Modes
Old 06-27-2015, 07:46 PM   #141
tslavant
My Ride: 2003 325I
Well my issues have been resolved! I decided to replace my spark plugs because they were due and to eliminate that variable. When pulling the plugs there was a black crust on some of the plugs. The car did run a bit better. So I took the car to the parts store to read the codes then clearing them. I drove the car till the light came back on. The code said to check coil number 4. I did some research and found a video on how to check your coils and super simple!!! So after replacing the coil my car runs fine, the I think I will replace them all!
tslavant is offline   Reply With Quote
Old 06-27-2015, 07:48 PM   #142
tslavant
My Ride: 2003 325I
Here's the video, this would have saved me a ton of time... But I did enjoy and doing all that I did! Thanks all the help guys!
Old 06-28-2015, 11:49 AM   #143
tslavant
My Ride: 2003 325I
So would you replace all the coils or just the one? I was thinking replace them all.
Old 06-28-2015, 11:50 AM   #144
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Only the one that is failing. Changing them all is a waste of money.
Old 08-16-2015, 01:48 PM   #145
tslavant
My Ride: 2003 325I
More issues
Well car ran great for awhile more cylinders are showing miss fire and running lean. I'm assuming and replacing the worst coils. Eventually I will replace them all. Also it miss fire intermittently, then times the car will go dead suddenly if I give it gas. I also have the wifi obd2 device. I have two oxengyn sensors bank one and bank 2 both say running lean. Are these working or are they bad, do I need to replace them? I did just replace the radiator, expansion tank , fan clutch and new fan sense a blade was broken off. It's amazing how cloged the radiator gets and in a place so hard to clean. if I would would have known that I would been more vigilant maintaining the radiator!
Old 12-17-2016, 10:25 AM   #146
malone
My Ride: 01 e46
I,ve had a similar idle problem for 4 years that seems to be getting progressively worse.
It's a 2001 325 Ci with manual xmsn. It runs great except at idle after coming to a stop.
When clutch is in or transmission in neutral the idle will fluctuate between 1000 and 400 then usually dies unless the engine is reved up. It is definitely affected by electrical load, ie head lights on or AC or heat blower on high. With any of those things off it still fluctuates but usually smoothes out.
I replaced the alternator which put out 14.1 volts at idle with a new, not rebuilt, to no avail.
No codes are thrown.
Smoke test for vac leaks were done by 2 independent shops indicated no vac leaks and read all data was normal with their SnapOn scanners.
I have replaced 'oil separator valve ', 'idle control valve ', 'DISA adjuster valve', 'throttle body', and all associated the boots and hoses.
After all of that, the problem went away for about a year. Now it's back!!!
The local dealer service dept. has never heard of this issue and wants the car for a week to start replacing components.
Any intelligent help would be greatly appreciated.
Last edited by malone; 12-17-2016 at 10:28 AM. Reason: I was trying to post this to the'Rough idle' Thread
malone is offline   Reply With Quote
Old 12-17-2016, 10:59 AM   #147
jfoj
My Ride: 330CiC, M5, X5, E93
malone,
I see you are new here and this is your first post.
You need to listen to me. DO NOT take your car to the dealer!!!
Spend $30 or less and buy the OBDFusion App for your phone or table and get the proper VeePeak wireless interface on Amazon.
Android requires Bluetooth, iProducts requires Wifi.
Then you need to read these threads at least 3 times, then get some sleep and then read them again.
http://forum.e46fanatics.com/showthread.php?t=1057387
I hear you say the engine has been smoke tested before and the SnapOn scanner info looked fine. Forget about all of this, if the brake booster is bad, a smoke test would not pick this up.
I have more test equipment and software than most of these E46's are worth, but for driveability I can do more with a $4 App than most "Professional" mechanics can with a $4000 SnapOn tool.
Suggest you start a new thread once you get the OBDFusion App and interface and I will provide info on how to set it up and gather data.
Old 12-17-2016, 12:48 PM   #148
tslavant
My Ride: 2003 325I
Do what he said above! But for quick check, check your coil packs it's easy to check. If it wasn't done.
Clean MAF, or it may need replaced. Also check your valve cover gasket, it will suck air and rain water in if bad. Easy replacement. Oh, run sea foam thru the gas!!! Twice. Your choice if you want to run it through the intake. I did and it helped.
Old 12-17-2016, 02:13 PM   #149
malone
My Ride: 01 e46
jfoj, your info is fantastic! Given all that's there, it will be awhile before I get back.
Thank you so much!!
rough idle
