Old 04-12-2017, 01:50 AM   #1
texlnghorn
My Ride: 330ci
330ci Interior LED Lights
Hello everyone,
This is my first post on these forums so if by chance I didn't do something right, just let me know so I can post correctly in the future. Anyways, I recently (somewhat) upgraded myself from a 2000 BMW 323i to a manual 2002 330ci. Back when I used to drive the 323i, I had installed a set of Zevo LED bulbs that I purchased from auto parts stores and Walmart to replace my stock interior lights. They worked perfectly, however, I tried doing the same on my 330ci, and all of the bulbs worked fine until I got to the footwell. After I put the last bulb in, all of the interior lights shut off and wouldn't come back on. I now know I need a resistor installed, but to be honest I do not want to install one. From my experience, they heat up very fast and get VERY hot, and I do not want something like this inside of my car, especially around the plastic dash pieces. So is there any way I can install the lights without needing any type of resistor, so I can use the Zevo bulbs I have? And why did the 323i lights work perfectly without the need for a resistor? I'd appreciate if someone could let me know. Thank you.
texlnghorn is offline   Reply With Quote
Old 04-12-2017, 10:01 AM   #2
illicitstylz
My Ride: 2000 328ci
Do the lights come back on if you do not use a LED in the footwell?
Sent from my ONE A2005 using E46Fanatics mobile app
illicitstylz is offline   Reply With Quote
Old 04-13-2017, 05:40 AM   #3
texlnghorn
My Ride: 330ci
Yes, the lights come back on once I replace the LED with the stock bulb.
Old 04-24-2017, 02:07 AM   #4
texlnghorn
My Ride: 330ci
Bump
Old 05-19-2017, 10:14 PM   #5
texlnghorn
My Ride: 330ci
Bump
interior, interior bulbs, interior led, led bulbs, resistors
