So i have an 02 325i and an 04 330xi..... - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 04-24-2017, 10:14 PM   #1
Atm_blazin
My Ride: 2002 325i
The 02 5 spd 325 needs valve seals and a clutch, the 04 6spd 330xi i bought to fix but after many tries at getting the driveshaft straight I've determined its got to be a problem in the rear end since it looks like they lowered it down on something when it was on a lift but the motor starts and runs great(despite having 201k miles) . So my plan is to swap motor ecu cluster and all into the 325 from the 330 then getting a limited slip differential to make the car more enjoyable
My questions are:
Are there differences in the 3.0 from an xi and non awd model?
Do i have to swap the wiring harness or should it just be plug and play?( besides the maf maybe from what I've searched still not clear on that)
Any suggestions on flywheel clutch combination?
Has anyone experienced suspension issues after the swap due to what i would only assume would be a slight increase in front end weight?
And are there any "common issues" with this swap.
I own both cars so all the parts are available i just rather know everything ahead of time to get a clear plan and document as i go along.
ID:	653988   Click image for larger version
Atm_blazin is offline   Reply With Quote
Old 04-26-2017, 05:07 PM   #2
Atm_blazin
My Ride: 2002 325i
Nothing????? Ill take a smart ass comment at this point like"use the search function" Like I'm not doing that all day in my spare time
3.0, 325, novice, swap
