Old 08-05-2013, 02:28 PM   #1
MrEmitter
My Ride: 2002 330ci
e46 in cabin noise
I need help identifying this annoying noise that I keep hearing. I want to know where it's coming from and what's causing it. Please help.
MrEmitter is offline   Reply With Quote
Old 08-05-2013, 02:30 PM   #2
My Ride: Lexus
there's a really high pitched whistling sound thats drowning out everything. sounds like feedback
Old 08-05-2013, 02:44 PM   #3
MrEmitter
My Ride: 2002 330ci
that's the noise I'm talking about. I can't tell where it's coming from. It just randomly starts so I can't reproduce it.
Old 08-05-2013, 03:34 PM   #4
My Ride: Lexus
That's really hard to identify. You sure we're talking about the same noise? I imagine anything that bad would be very obvious. Sounds like the sound system??
Old 08-05-2013, 03:49 PM   #5
Yewzer B Lewzer
My Ride: 2003 325i
Turn off everything until the noise is gone including blower fan, ac, radio, engine. Then back on one at a time, ignition position 1, then 2, then start it. Then turn on things one by one.
^^Blue Ridge Parkway^^ '03 325i. '74 Jeep CJ-5. '93 Sailfish 170XL. '12 Westside SS Longboard. One of these four are sure to be running at any given point in time.
Yewzer B Lewzer is offline   Reply With Quote
Old 08-05-2013, 04:02 PM   #6
adrian8507
My Ride: E46 325xi 2002
Re: e46 in cabin noise
Is your engine running when the noise is produced?
Sent from my SPH-D710BST using BimmerApp mobile app
adrian8507 is offline   Reply With Quote
Old 08-05-2013, 04:23 PM   #7
MrEmitter
My Ride: 2002 330ci
The noise is produced only when the engine is on. And yes Mango we are talking about the same sound the high pitched you hear on the video. Other noise on the video is the sound of the car being driven in slow speed. The noise btw isn't speed related because this happens when I'm on the freeway.
Old 08-05-2013, 04:51 PM   #8
adrian8507
It probabbly static from your radio . Usually this happens when your ground is not connected properly on your radio components
Old 03-14-2015, 11:39 PM   #9
Tlrtucker
My Ride: 2003 330xi
Resurrecting an old thread here. I've been having the same exact noise and its driving me crazy. It sounds exactly like your noise, it is totally independent from speed, is there regardless of if the radio or climate control is on. It only lasts 5 to 10 minutes then it goes away. It sounds like it's coming from either the gauge cluster or the tweeter mounted on the door.
Did you ever fix this problem?
Tlrtucker is offline   Reply With Quote
cabin, e46, noise
