Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Complete Cars - Private
Old 08-08-2013, 03:17 AM   #1
M3reacher
My Ride: E 46 M3 2002
2002 M3 6M Carbon Black 97K miles STOCK. DC, VA, MD
Hi All,
I am feeling a mild pain in my heart as I write this proclamation to part with my M3. I have taken much care of it and fixed every thing that I could fix (get fixed) very meticulously. I am the fourth owner of the car but I feel like its been mine ever since it was born.
I need to sell it as I now I have a human admittance in my life which requires more attention.
A little about the car.
It has 97,000 miles on it but still drives like a charm. I bought it in December 2012 when it had 91,000 Miles and fixed everything that had to be fixed( there were not too many issues at that time). It is ALL STOCK. Carbon Black with Dove Gray interior. It does NOT have any ISSUES whatsoever except some aging and chips on the front bumper and the sun roof inside lid is vibrating and i will get that fixed soon (not the sun root itself) .EVERYTHING WORKS. Clean Car FAX. It has never seen Track.
The oil change was done at 96000 and got everything doneat RRT racing( they are better than dealer for M3's in DC area)
Done at 91000
Oil Filter Kit
10W60TWS engine Oil
Breakpad and rotors replaced
Drive shaft
pinion seal
Wiper Insert
Air Filter Original Equipment
ACC Cabin Filter Activated Charcoal
Motul DOT 5.1 Brake Fluid
Motul Multi-ATF Technosynthese
E46 M3 Rear Trailing Arm Bushings
RRT Rear Trailing Arm Bushing Shims
Valve Cover Seal Washer
Valve Cover Gasket - OEM BMW ONLY
Spark Plug Tube Seals
VANOS to head gasket
Oil Relief Valve
Door Lock w/ Motor Actuator
Clean and adjust rear brakes
Replace constant pressure valve
Reseal VANOS to cylinder head. Due to having to
remove the valve cover and front timing assembly,
performed a valve adjustment at the
same time.
Flush power steering fluid
Flush brake system and bleed ABS pump
Differrential servise done
Done at 95000
Oil Filter Kit
10W60TWS engine Oil.
Muffler Hanger
ST Shift Bushings
Selector Rod
Shift Lever bushing
Recently got the windows tainted.
It has 18 OEM wheels Staggered Setup.
I will accept offers not below $16,500/-.Please call or text (757-2zero2-7394)
Thanks for looking.
http://s1361.photobucket.com/user/M3reacher/slideshow/_a_
M3reacher is offline   Reply With Quote
325, e46, m3, staggard, stock
