Old 09-05-2013, 07:13 PM   #1
NarekE46
My Ride: 2001 325i
Loud fan...?
I've had my car for a few months now and after my far right gauge (water temp) reaches the middle and the outside temperature is in the high 85 degrees + my car's fan turns on and it's REALLLLLYYYYY loud, I want to know if I'm the only one that has this? and is there a way to fix it? The fan turns off if the temperature is low 80's and below
NarekE46 is offline   Reply With Quote
Old 09-05-2013, 07:14 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
It's normal. It's your auxiliary fan turning on to cool off the car.
But to make sure the car is not running hotter than normal check the coolant temperature using the hidden obc function
Old 09-05-2013, 07:17 PM   #3
NarekE46
My Ride: 2001 325i
Can you tell me the OBC function for the coolant temperature? and what's the normal temperature?
Old 09-05-2013, 07:28 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
anything up to 98C let's say
http://www.bimmerfest.com/wiki/index...uter_Functions
cooling, cooling fan, fan, water temperature
