Help! Oil leak! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-27-2013, 10:38 AM   #1
lucianoromero
My Ride: 2005 330ci
Unhappy Help! Oil leak!
Hey guys, I'm new to this forum and this is my first post.
Recently I've been having issues with my '05 330ci leaking oil. I just got under and realized that there was oil leaking down from the front skid plate. As I looked closer I noticed that the steering rack was covered in oil. This weekend I'm going to get a better look, but I wanted to know if anyone has had similar issues/solutions.
Thanks!
ID:	528514   Click image for larger version
ID:	528515   Click image for larger version
lucianoromero is offline   Reply With Quote
Old 09-27-2013, 10:47 AM   #2
YaSureYouBetcha
My Ride: 2002 325xi
Help! Oil leak!
Check the filter housing. Common seal failure...
YaSureYouBetcha is offline   Reply With Quote
Old 09-27-2013, 02:55 PM   #3
dznuts007
My Ride: 2001 325i Sedan
I think we pretty much all have had an oil leak. The OFHG leak is very common as mentioned above. A good way is to really clean up the areas with a degreaser then give it some time and keep checking back to see the source of the leak.
dznuts007 is offline   Reply With Quote
Old 09-27-2013, 03:39 PM   #4
jake328ci
My Ride: 2000 328ci
[QUOTE=YaSureYouBetcha;15734055]Check the filter housing. Common seal failure...
oh yeah that is what the problem was on my friends 330ci and i am regularly checking for leaks on my 328. im a leak freak ever since i had a leak in my e36 318is that i let a family member drive while she figured out her car issues and ended up with a rod knock. not good at all always fix an oil leak
jake328ci is offline   Reply With Quote
Old 09-27-2013, 06:28 PM   #5
lucianoromero
My Ride: 2005 330ci
Help! Oil leak!
Thanks guys! Now I have something to look for when I go under. I'm going to try to change some seals, since this Miami heat will deteriorate anything. I heard the VANOS seals are also notorious for having this issue, but I don't think that's what could've caused this...
Old 11-02-2013, 04:56 PM   #6
shootthehorses
My Ride: 2002 BMW 325i Sedan
It sounds like the oil filter housing gasket to me. I found a new Bimmer mechanic whose price to R&R it is $300, including an oil service. He did some other work while he was there, including the transmission service, and I am very happy with his work. No more oil all over the floor of my garage, and no more putting in a quart of oil every 1,000 miles!
shootthehorses is offline   Reply With Quote
Old 11-02-2013, 05:45 PM   #7
av516
My Ride: 2006 M3 ZCP IB
same leak here
mech said OFHG
av516 is offline   Reply With Quote
Old 11-02-2013, 06:09 PM   #8
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
pics of the pan are useless, leak could be anywhere
pop hod, get a flashlight and start feeling around
ofhg
vcg
sensor o-rings
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 11-03-2013, 07:03 AM   #9
havnfun328
My Ride: '99 328i, '03 M5
Find the most forward and highest point that has oil on it.
Power steering return hoses are another common leak and can look like regular oil.
Also oil pan gasket can leak too.
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
Old 11-03-2013, 08:45 AM   #10
7xWDC-MSC
My Ride: 2005 325xi
Get a flashlight and peek down behind the oil filter housing at the block, if the OFHG is leaking, oil will collect on the side of the engine block.
Rubs the roundel on its skin or else it gets the hose again.
7xWDC-MSC is offline   Reply With Quote
330ci, help needed, leak, oil, problem
