Old 11-04-2013, 06:10 PM   #1
thatscoolimnick
My Ride: 2004 325i
Strange "bass" type vibration under load 2004 325i
Hi All,
New member here, just bought a 2004 325i w/ 180k.
I started to notice a bass type noise while in gear under load going 20-40mph
Happens most often between 1500 to 3000 rpm
It almost sounds as if there is a hole in my exaust but it only happens while in gear.
Any Ideas Would be great.
Thanks!
thatscoolimnick is offline   Reply With Quote
Old 11-04-2013, 06:20 PM   #2
JapanRot325ci
My Ride: 04 E46
a video would help
JapanRot325ci is offline   Reply With Quote
Old 11-04-2013, 06:42 PM   #3
7xWDC-MSC
My Ride: 2005 325xi
Possibly a wheel bearing.
Rubs the roundel on its skin or else it gets the hose again.
7xWDC-MSC is offline   Reply With Quote
Old 11-04-2013, 07:12 PM   #4
thatscoolimnick
My Ride: 2004 325i
ill see if my phone can pick up the noise.
the noise seems to go away above 3500 rpm and when im above about 45mph
it sounds is weird to decribe, its a low vibration as if i had a fart can on my car, or when you hit one of those warning strips on the side of the highway but not as pronunced.
If it helps im almost positive there are other issues witht the power steering and the rear brakes. Dont know if it could be related.
Old 11-04-2013, 07:46 PM   #5
Sweetness
My Ride: '01 325i
My magnaflow catback does this, but only between 2000 and 3000 RPMS.
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 11-04-2013, 09:02 PM   #6
TheFix330i
My Ride: 2003 330i
Sounds like your guibo and center support bearing on the drive shaft
TheFix330i is offline   Reply With Quote
Old 11-04-2013, 09:53 PM   #7
jmillsner
My Ride: 330Ci 6 Spd, 335Cic
could it be a motor mount?
jmillsner is offline   Reply With Quote
Old 11-04-2013, 10:15 PM   #8
Cowspoo
My Ride: 328Ci
The bass sound when you're still in 5th gear going 30 mph @ 1.5k RPM?
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
Old 11-04-2013, 11:13 PM   #9
JuniorT
My Ride: 01 325i & 06 330 ZHP
I have the same issue going at highway speeds usually kicks in between 1900 and 2100 RPM. Sometimes, rarely it's gets strong and loud enough to make the car shake pretty forcefully. It can happen either when under load or on decelerating.
JuniorT is offline   Reply With Quote
Old 11-04-2013, 11:41 PM   #10
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
Re: Strange "bass" type vibration under load 2004 325i
There was another thread today where i posted the same.
It can be a bad torque converter for the transmission. I had the same vibration around 1600 rpm and around 40mph. I thought it was a bad driveshaft bearing and guibo but after replacing those 2, I still had the vibration. 1 week after that I was on driving on the highway when the transmission light came on and car started smoking, when I pulled over it had leaked all the fluid. When we took out the transmission at my dad's shop, the torque converter had spun on to the bearing for transmission pump.
Sent from my SCH-I545 using BimmerApp mobile app
rizwan1377 is offline   Reply With Quote
Old 11-05-2013, 03:14 PM   #11
thatscoolimnick
My Ride: 2004 325i
thanks for the ideas,
took it to the shop today and was told that it is a bad u joint.
was also told that in order to replace the u joint they would need to replace the entire driveshaft assembley.
thats what was causing the noise anyways.
I also have bad control arms and a bent wheel.
Any diy's on replaceing the driveshaft assembly would be helpful.
Thanks!
Old 11-05-2013, 03:16 PM   #12
thatscoolimnick
My Ride: 2004 325i
and yeah cowspoo that was exactly it.. i think.. mine is an auto so im not positive its always when im in 5th
Old 11-05-2013, 04:36 PM   #13
rizwan1377
Hope its just a u-joint. It isn't hard to DIY if you have acess to a lift because you will have to take the exhaust off.
Old 11-05-2013, 06:48 PM   #14
thatscoolimnick
My Ride: 2004 325i
Getting fixed this week, Ill update if its really "fixed"
Old 11-05-2013, 07:16 PM   #15
Cowspoo
My Ride: 328Ci
Interesting post. I didn't think anything was broken. Just a high gear and low rev's
spacebarissolazy
Old 11-06-2013, 04:22 AM   #16
vengefulgod
My Ride: 325i
I had the same sound. like a 1 long "boom" bass sound right? the sounds would last as long as saying the word "boom". My car was doing it only at low speeds. I got my trans fluid flushed and changed and it has not happened since. been like 5 months.
vengefulgod is offline   Reply With Quote
Old 11-25-2013, 06:09 PM   #17
thatscoolimnick
My Ride: 2004 325i
figured id give an update, driveshaft done! noise gone!
load, vibration
