Old 11-20-2013, 12:18 AM   #41
Dice9309@yahoo.com
My Ride: Bmw 2000 323i
Re: e46 Loud POP, Poor acceleration, Bogging. Please Advise
Some times there is data n sometime no my o2 senors get what is attached but I usually see 0.4
Sent from my SCH-I535 using BimmerApp mobile app
Dice9309@yahoo.com is offline   Reply With Quote
Old 11-20-2013, 09:58 AM   #42
Dice9309@yahoo.com
I thonk my pre cat o2 senors are bad
ID:	535529   Click image for larger version
Old 11-20-2013, 03:04 PM   #43
jfoj
My Ride: 330CiC, M5, X5, E93
I may be dead wrong here, but humor me for a moment.
Take a few minutes and check the O2 sensor wiring VERY carefully.
First to make sure everything is plugged in fully, BUT there is a situation where people can REALLY screw up the O2 sensors connections. I recall there is a gender difference between the front and rear O2 sensors and the connections are close to each other. We have seen a lot of cases with the O2 sensors sometimes are plugged into each other and the car harness is also plugged into the other gender connector on the car.
This causes NO O2 signal to be fed to the the DME.
You could have one side connected properly and another side connected in a way that the front and rear O2 sensors are plugged into each other and the harness from the car is plugged into the other connector on the cars harness.
Then to make matters worse, you then need to unplug one O2 sensor at a time to make sure the sensors are connected to the proper bank on the wiring harness.
Hope this makes sense??
Assume nothing is correct going under the hood and you will be FAR better off in the end!
Let me know what you find.
Old 11-27-2013, 12:35 PM   #44
Dice9309@yahoo.com
Cleaned the senors connections n I got this
First two pic when I started the car
After going to work the o2 get volts when decelerating third pic shows that
ID:	536374   Click image for larger version
ID:	536375   Click image for larger version
Old 11-28-2013, 08:57 AM   #45
Dice9309@yahoo.com
Second picture is wrong
Old 11-28-2013, 09:19 AM   #46
jfoj
Fuel trims this high lead me to think there is a MASSIVE air leak.
Old 11-28-2013, 10:34 AM   #47
Dice9309@yahoo.com
Happy thanksgiving
Yea I think might be the cause of the intake back fire. Trying to find someone who does smoke test locally but nothing so far
Old 11-29-2013, 02:01 PM   #48
jfoj
Originally Posted by Dice9309@yahoo.com View Post
Happy thanksgiving
Redneck smoke tester, cheap cigar, a rubber glove and some vacuum line, or make your own with PVC pipe and baby oil.
Old 11-29-2013, 04:19 PM   #49
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
dice , are those pics from tq app?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 11-29-2013, 06:13 PM   #50
Dice9309@yahoo.com
Ill try to find a friend who smokes lol
N yes sir its a different theme
Old 12-01-2013, 03:22 PM   #51
Dice9309@yahoo.com
So found my leak sap line was torn.
Also seem to of found another problem.
My intake valve seems to be bent I tried taking the best picture.
Old 12-25-2013, 03:43 AM   #52
Dice9309@yahoo.com
Solved this problem
Replaced
vacuum lines
Intake manifold gasket
And mafia was fault.
Old 09-09-2016, 02:13 AM   #53
Neufusion
My Ride: 2000 323i
Solved this problem
Replaced
vacuum lines
I have the exact same car and symptoms.
Did you mean the MAF sensor was at fault? You had to clean it or replace it?
Neufusion is offline   Reply With Quote
Old 09-26-2016, 10:20 AM   #54
Neufusion
My Ride: 2000 323i
For me, it turned out be a faulty MAF. Replaced with a $220 OEM MAF. Runs like a champ.
2000 BMW 323i Auto
bogging, e46, loud pop, poor acceleration, sedan
