No electric trunk release buttons work - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-24-2013, 08:45 PM   #1
sarwaria23
My Ride: 2001 330CI
So none of the electric trunk release buttons on my 2001 330ci convertible work. Not the one on the key, in the cockpit, or the one on the trunk. I read on here that it is a common problem and the common solution was to check the wire from the trunk, so i checked them and soldered the cut ones and loose ones. but still none of the buttons work. Any thoughts or solutions???
sarwaria23 is offline   Reply With Quote
Old 11-24-2013, 08:59 PM   #2
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
Lets see pics of your repair work.
Cavi Mike is offline   Reply With Quote
Old 11-24-2013, 09:37 PM   #3
cityjohn
My Ride: 2001 M3
Turning the glovebox key all the way to the right disables cockpit and trunk switches but not key, so that's probably not it. I'm guessing the wires, and they can be deceptive. Pull each one to make certain there isn't a break in the conductor hidden by the insulation.
cityjohn is offline   Reply With Quote
Old 11-25-2013, 01:33 AM   #4
sarwaria23
My Ride: 2001 330CI
This is so frustrating! Ill double check the wires is there any fuse related to the trunk release? Could it be a fuse?
Old 11-25-2013, 01:37 AM   #5
cityjohn
My Ride: 2001 M3
Maybe #60? But I think if that were blown then your doorlocks wouldn't work either. Inspect your elephant and tug your trunk.
Old 11-25-2013, 07:34 AM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
+1...yank all the wires apart. If you didn't know, you can cut the ziptie on the bottom of the rubber boot covering the loom (from inside the trunk), then feed the boot into the trunk (leave last grommet sticking just out so you can get it up again). Yank from the top and bottom as the breaks will be where the wires fold when closing the trunk lid.
Bet it is this. Before soldering/shrink tubing...just connect the wires 'dry' and make sure that fixes your issue...bet it will...hope so anyway!
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
fuse, problem, trunk, trunk release, wiring
