Old 12-28-2013, 06:25 PM   #1
Tlvivo
My Ride: 320i Individual
Stumped - loss of power, rough idle
This happened out of the blue, taking off from stationary position - limp mode?
air leak? HEEEELLPPP!!!
http://s131.photobucket.com/user/Tlv...a063b.mp4.html
Tlvivo is offline   Reply With Quote
Old 12-28-2013, 07:22 PM   #2
Zchild
My Ride: 2000 BMW 3XXi ZSP
Sounds like a vacuum leak somewhere around your intake hoses. I start with their security and check for tears and or cracks. Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 12-28-2013, 09:51 PM   #3
lszlszx
My Ride: 1.8T, XC70
Scan for codes.
How old is your fuel pump and filter, it could be fuel supply issue.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 12-30-2013, 12:53 AM   #4
Tlvivo
Fuel pump was replaced - a year ago / year and a half ago... Can this be a result of a very badly corroded fuel tank? At some point but that was almost two yeas ago! When the petrol gauge got to 1/4 the car would die and not start with a symptom of no fuel.... Topping up the fuel would get the car going nicely again.
I'll get the codes read, but I am also suspecting air leak, the only thing that has me perplexed is how can the car be going good for almost the whole day and then only start this later in the evening without warning...
Old 12-30-2013, 01:03 AM   #5
Swater330i
My Ride: 2003 BMW 330i 5MT
The dying at 1/4 a tank can be a sign of a bad fuel pump. After you replaced the FP did that solve this issue or does it still happen?
When was the last time the fuel filter was replaced?
Originally Posted by phenom323ci View Post
I am going to install M3 fender grill on my 323ci.
Originally Posted by futureSubie View Post
IMO, the euro clear corners looks too aftermarket/ricey.
Originally Posted by Davconelectric View Post
This 323 would most likely handle and drive better than a stock e46 m3.
Swater330i is offline   Reply With Quote
Old 01-09-2014, 05:52 PM   #6
Tlvivo
gents thanks for your responses... I havent had time to have a look at the car - so have parked it for now!! As soon as I start with it again I will update.
Old 01-09-2014, 06:24 PM   #7
Willie00328I
My Ride: 2000 328I sedan
Ya scan the codes. maybe a bad coil, causes a very rough idle and loss of power. When my car went into limp mode I could turn off the car and restart it then it would not be in limp mode anymore. I agree on checking intake boots, mine were very bad and torn, there cheap I'd replace them anyways at your mileage. Check your vacuum lines, mine were cracked and brittle.
Willie
Willie00328I is offline   Reply With Quote
Old 01-09-2014, 06:45 PM   #8
Tlvivo
thanks Willie..
